Chemical ratio chart
Discussion in 'Talk About Developing Film' started by John Shiell, Dec 9, 2018.
  1. John Shiell
    John Shiell New Member Registered User
    Aug 17, 2016
    2
    0
    1
    Dartmoor, Devon
    I used to have a printed ratio chart up on the wall of my darkroom for all my chemicals. It was just an easy view on trying to determine the amounts. It was for 1 litre of mixed chemical. Sadly it has been destroyed.
    Does anyone out there know where I can download this chart.
  2. Ian Grant
    758
    111
    West Midlands
    I've never seen a Chart but then most of the chemistry I use is simple and logical quantities like !+9, 1+19, or 1+1 to 100.
    I never used the 1+50 for Rodinal to be literal, actually mixing 1+49 which is one part developer diluted to make 50, so 20ml dev to make 1 litre.
    You can use a spreadsheet to do more complex ratios and make your own chart for the chemicals you use.
  3. James T
    James T New Member Registered User
    Oct 19, 2018
    25
    5
    3
    Oxfordshire
    Here is a PDF version of the spreadsheet that I use mainly for 1-shot developers.
    (The forum does not appear to allow .xls or .ods files, so I can't upload an editable version)
  4. David M
    Jan 29, 2017
    1,123
    94
    48
    South London
    Massive Dev Chart will do this. When you've chosen film and developer, it will calculate amounts for your required volume.
  5. John Shiell
    Aug 17, 2016
    2
    0
    1
    Dartmoor, Devon
    Thank you... just what the Doctor ordered!
