Why Can't I Produce Images Like This
This is a photograph made in 1895 and the location is about 1 mile from where I live.
I have stood many times looking at the bridge from more or less the same place the photographer is stood and even made exposures on FP4, Foma 200, Kodak TRIX 5x4 film with my 150mm and 90mm lens but I just cannot seem to get the pictorial look I am seeing in this image.
It's the combination of early dry plate emulsions, the lens used, then the printing process. The first papers using Baryta were introduced in 1894. The nearest modern equivalent would be an Art paper, but that would have been a POP paper, or maybe an Albumen print.
Modern lenses and films won't give you that look.
You probably cannot get that exact look but you can try to approach it by doing three things:
  1. Expose and develop the film for lower contrast. Avoid dilute developers as they tend to raise sharpness which isn't what you want here. D-23 stock would be a good first try.
  2. Split VC print (or do curve adjustments) to keep the blacks on the darker side while maintaining lower contrast highlights
  3. Use diffusion below the enlarger lens while printing. The easiest way to do this is to stretch a piece of a sheer woman''s neutral-colored nylon stocking over a cardboard frame with a sufficiently large opening. Secure the stocking to the edges of the frame to keep it stretched. You can then hold this below the enlarger and keep it in continuous motion during the exposure. This will soften the image noticeably. (If you're doing the "printing" on a computer, tools for diffusion exist.)
Would getting an older lens for the 5x4 and a modern film get close?
It was likely shot with a Rapid Rectilinear lens, they were introduced by J.H. Dallmeyer in 1866, photography was expensive on 1890s. RR lenses aren't bad performers. Films weren't spectrally sensitised in 1894, so you'd need to use Ortho film, and that image is a long exposure, the fastest Ilford Plate in 1895 was equivalent to 13 ISO today
If you've seen images on Ilford art paper or the older Kentmere Art the emulsions are coated on the textured paper base, in the same way as Salt prints, Platinum prints, Kallitypes etc. None of these copy well, you lose detail and apparent sharpness. It's similar to pearl, lustre, satin VC prints not scanning well. It could be a Carbon print.
The closets you'd get would be making Kallitypes, which is not difficult but it's a contact print process.
The only modern photographer to get close to that look was James RAvilious, he used a Leica with a Summar.
I suggested looking at James Ravilious because he obtained that fairly similar look by using pre-WWII Leitz Summar lenses. These were Leitz's first fast 50mm f2 lenses, uncoated they are brilliantly sharp and fairly low contrast.
So some lateral thinking for LF use you'd want a cheap un-coated Dialyte, with 6 internal air/glass surfaces they would have similar low contrast to a Summar. I say cheap meaning a budget lens, because the best Dialytes are very sharp lenses like the Goerz Celor/Dogmat, Rodenstock Eurynar, the dialyte, Kodak Anatigmat/Ektars.
C.P. Goerz (Berlin) for instance offered a number of different Dialytes at one time some faster others slower, they are difficult lenses to optimises as the front and rear elements need to match perfectly, so there were the premium versions, a middle grade, and then budget lenses, and the price difference where substantial, as was sharpness.
You can use a Wratten 44a, Hoya etc 80a, filter with Panchromatic film to emulate Ortho with the added benefit of a speed drop :D Then print on Ilford Art paper, or Inkjet print to something similar.
I have an uncoated 50mm collapsible Elmar on my Leica IIIf. As you say, this generation of lenses was tack sharp but low in contrast and it really hates being pointed at specular highlights. A collapsible Summicron is on my wish list to augment it.
I have an uncoated 50mm collapsible Elmar on my Leica IIIf. As you say, this generation of lenses was tack sharp but low in contrast and it really hates being pointed at a specular highlights. A collapsible Summicron is on my wish list to augment it.
The Elmar has a lot more contrast than the Summar or uncoated Summitars, I know as I have a pre WWII Elmar and Summar, Summicrons are very different they are all coated or later multicoated. My 50mm Summicron earlm1960s is an amazingly sharp lens, with excellent contrast.
It probably has good contrast they are Beck RR lenses, I have a few of them. Look at Brassai and Kertez's pre-WWII work that has the look you are asking about they are most likely shot with a Dialyte.
Ian B.,
to me the main thing seen in old photographs is that this guys have had a damned good idea about light.
And they really knew how to use there tools for managing contrast. Later I will tell more about.
If you want to keep approximatively the same image impression/appearance, one first have to study the original.
In doing this, a lot of darkroom work will appear.
The main thing jumping to my eye is a somehow not realistic difference between overall contrast and the persons in the boat.
Here I don't believe in an extra sharp lens but in (too much?) retouching.
On the other hand the persons look badly photoshopped, so an unprofessional copying-in strategie may have been done - the sharp edges of boat and foreground person also recommend a sharp face but I can't see a sharp face.
Ok, could have been some facial movement, but..
Shadows look ugly reduced as it will happen with the usage of a way too strong reducer solution or by overdoing the reduction.
The area right from the boat at least leads me to the question if you really want to repoduce such a horrible picture :D
Back to the tools and negative contrast as said before:
Concerning their materials of bad contrast range the old photographers had to do lots of tricks.
They didn't only develop negatives and positives but they "evoke" the images.
The negatives with three or mor baths of differnt developers and/or solutions, done under control with dark light, this later after a necessary narcotizing the panchroatic (light sensitive!) plates with Pinacryptol.
The prints on non MC papers with techniques known well and beyond.
Concerning the sadly remaining of only a handful of simple print papers without great silver conent nor special characteres I don't believe in reproducing old photographs in 1:1 ratio.
But I absolutely believe in reaching nearly the same appearance, yes.
In my opinion the right tool has to be a mild lens, eventually a soft focus lens.
Could be an old Xenar, could better be a simple meniscus lens.
It will better handle harsh contrast situations.
Even wide open it will give a wide range of "sharpness" in the depth of field, bringing some flair to the print.
It will "describe"the light ( I believe that there has been a more bright light as seen in the example) and it will give a fine rendering, both bringing the mystic to the image.
This is a poor example (a narrow scene) but I have done with an uncorked meniscus lens coming from a typical ancient f/16 landscape lens:
And this fabulous picture has been the reason years ago giving my money to Stephane from LFPF for buying the old (but still complete) lens:
Both pictures give lots of DOF, both lack contrast and give mildness, in my words a kind of mystic.
No problem to darken, sharpen or otherwise manipulating certain areas coming soft and less contrasty from the lens - later in the darkroom then.
Best,
Reginald
When you look at the image larger it is very apparent that there is movement in the water, as I write it's sunny and 100 ISO film would be 125 @ f16 using my Lunasix F, almost the Sunny 16 rule of thumb. However, in 1895 Ilford's fastest plates launched that year were the equivalent of 13 ISO, most were more like 6 to 9 ISO so the exposure at f15 would be around 1/8 to 1/15 of a second. If it was weak sunlight then you would be looking at even longer exposures.
It's worth looking at James RAvilious' work here's a link. He was looking for, and obtained, that dream like pictorial look that harks back to Emerson etc.
Just updated/changed the link.
Actually, looking closely at this image, I would say someone has been playing with AI. The boat is perfectly sharp, including the oars, the left one of which actually looks sharpened. The boat shows absolutely no signs of movement and yet the river is running, as evidenced by the blurred flotsam.
What you are seeing is a scan from the original glass plate
Now you've said it's a scan of a plate, it's likely the slight softness, in terms of sharpness, is actually caused by camera vibration during the long exposure. The boat is tied up, and it looks like the women are using the oars to keep it in position, my gut feeling is that's a second or so exposure.
In terms of perspective it appears to have been taken with a longer lens, equivalent to a 180mm or 210mm in a 5x4 camera.
It was looking at how sharp the oars (as well as the while boat) are in relation to the movement of the water that caused me to doubt that is was one single image.
That was my feeling.
Don't get me wrong, it's a lovely image but I just got that sense of Uncanny Valley with what I perceived as an anomaly in the softness.
I think that perceived anomaly is down to the developing techniques of 1895, in general negatives were over-exposed, compared to how we work today, and also developed to a much higher contrast using quite strong fast acting Pyrogallol based developers. These negatives print well with POP papers and processes like Kallitype, Albumen printing etc.
It's likely that the developer has created quite strong edge effects on those oars, and also the boat, exaggerating these edges.
In my youth I was involved in a local history book, copying images and negative from this period, the glass plates from the pre-1900 era are very difficult to print on modern papers, as I found. Museums in the US used Centennial POP paper, made for the Chicago Albumen Company by Kentmere, who sold it under their own name here, It was discontinued when Ilford bought Kentmere due to health and safety issues. Essentially the paper incorporated raw Silver Nitrate which contaminates the coating line, Kentmere coated it as their last coating run before Christmas every year, then had their much smaller coating line stripped down and cleaned over the Christmas holiday. Modern papers and films have a protective Gelatin top layer, so only a very small section of the coating line needs cleaning between different emulsion coatings. With POP every thing needs de-contaminating that includes the confectioning machinery used for cutting and packaging, it's a huge job.
Ilford thought coating a POP paper would breach their stringent Health and Safety standards, and they have had numerous awards over the years for their very high H&S and also environmental standards.
Haven't seen the original plate, but a little retouching was commonplace in the good old days.
Due to contrasty scenes not fitting the ancient materials a full retouching was common.
It started with the negative and ended with a kind of painting the positive.
After begging and pleading I was given some private but retouched plates from a photographer who learned in a studio anno 1955, and where she had to retouch every negative.
She told me that she mostly worked from two to five minutes on a negative but sometimes it also needed up to 15 minutes .
I got a contact print of a plate, too, and as Ian has said it is hard if not impossible to reach the rich of the original from modern papers.
This (orthographic) paper negative gave me black instead of deep brown bottles.
I retouched them with a ballpen, and I did scary experiments:
It's amazing what could be done with "retouching".
One also could dodge and burn with multiple copying the print back to a negative, than back again.
Still not talk about painting whole mountains , removing or bringing in clouds to the sky nor Mortensen's Abrasion Technique which it's totally control over highlights, midtones and shadows reminds me of Bromoil printing...
What I have learned is this:
Never believe an ancient print ;)
I met a photographer who worked at Leyland Motors after his discharge from the navy, also as a photographer, and his speciality was retouching plates.
Incidentally, he told me about an incident on a battleship where the blast from the guns shattered the glass plate in his camera.
On another matter which came up previously, what is the difference between POP paper and this, very slow, contact paper?
