Gebr. Schreck Cable releases
Soulstar89
Hey peeps. Hope every is enjoying the amazing weather and catching a tan lol.
I was recommended this German company for cable releases. I keep on breaking mine, I don’t know why as I’m not heavy handed lol. On the website it instructs non EU customers to send a email to request a quote. I have done this twice and I have had zero response. Has anyone used this company and have you gotten a email response?
Cheers
I've bought from them on numerous occasions but this was before Brexit came into force, so I was able to order via their "shop". Alternatives that are available in the UK, and look to be made by Gebr. Schreck, are sold by Linhof Studio. They sell Linhof and Silvestri cable releases, but the choice of different types of release, length, material and colour is more limited, and they don't stock those very useful extensions that I leave permanently attached to the lens. And don't forget all prices need VAT to be added.
Morning collas.
I actually saw your post on a thread about cable releases last year. It was helpful in regards to knowing that silvestri, kasier and others I’ve seen that look similar are made by them.
You are right about choice. I wanted a wire mesh outer layer rather than plastic as all my other cable releases I’ve had begin start coming apart exactly where the metal end which attaches to the lens and the plastic coating starts. Lengths, outer coatings and colour is a great option also.
I may have to make do with a plastic version made by another brand.
Appreciate you reaching out
You can get this stuff which is adhesive-lined heat-shrink tubing very cheaply which is designed for repairing electrical cables and the like. Works wonders for repairing cable releases. You cut it to length, slide it over the bit you need to repair then hold over either a heatgun or a candle, carefully turning it. Will save you a small fortune in phone usb cables too. This cable release is the one in my main 5x4" kit, must be well over ten years, hundreds of shots and of heavy use now.
I will say that generally speaking, no matter how much money you spend on cable releases, even paying a ton for one from Linho££ $tudio, leaving them screwed into each lens when packed away in a beg eventually is fatal in terms of wear at the screw end. Those short 10cm extensions, if you can find them, are godsends and totally prevent any sort of wear at that end, so you can get decades out of one decent quality release which you use for all lenses.
Heatshrink tubing a great idea...however - DONT use a naked flame to shrink it..use a hair drier or heatgun (the latter atl east 6 inches away from the job)
Thanks for tips Dave. Good advise. You have a material or metal outer casing which is much more supple than plastic. The area you reinforced with shrinking plastic is smart.
Having extension leads on all my lenses to is another great idea as I sometimes forget to attach cable releases when setup up and leveling camera . So many little tips to learn
I've got both a hairdrier (unnecessary for me, granted) and a heatgun, and yet I still use a flame with no problems. Just be patient and don't hold it too close, and don't do anything daft.
II am patient..I sell the stuff to aeromodellers and the number that ruin the job by using an open flame!
Good for business!:D
Thanks Joanna. Process supplies have one in store and it’s a 15 min bike ride so if I can’t get one from Gebr. Schreck with the specs I’m looking for I’ll purchase from them.
I misplaced my cable release shutter adapter. (came with the Schneider lens i purchased )..took ages to find and became more frenzied when I checked the price of a new one!! :D
I don't know what everyone's doing with their cable releases but I've never bought one new and I've never had one break!
However, I have seen plenty of broken ones at camera fairs and especially ones with threaded tips that are too short or broken off?
Here's some of mine....
I have two. cable releases.....A short all metal one I've had since 1968 (NOT a braided metal cover but a spring type cover! ) -
I aso have a longer plastic cheapo...just in case................... :D
:eek:Show off lmao.
This is my current cable release. I don’t know how the bottom plastic has separated. It’s getting worse hence me wanting to get a better quality one.
I get through cable releases, I also find a need for different types depending on the shutters used. For multiple exposures, the lightweight cloth or braided metal one are the best. The heavier, less flexible, plastic covered ones can cause slight movement of the camera.
Then there's length of throw, I used some front mounted leaf shutters, Gitzo, LUC, AGI, etc, some need a longer throw than many cable releases are capable of, they cock and then release the shutter in one depression. Press shutters like Prontor, Ibsor, Betax & Alpax are the same, and hey also stress lighter cable releases quickly.
And then there's the really heavy duty Sinar Copal DB shutter cables, they have 40mm throw, and need quite a lot of pressure in use. First pressure stop down the aperture, second cocks the shutter, and the final third push trips the shutter.
Like @MartyNL I have quite a lot of cable releases. In recent years I've bought them in bulk at Camera Fairs, back maybe 2007/8 I asked a stallholder how much are your cable releases, you can have the lot for £20, there were more than 20. I think I sold one that covered that purchase, it was non-standard in terms of fit.
As @Dave_P posted the electrical heat shrink insulation tubing is very useful. I've rescued a few cable releases using it, I also usec it to reinforce a new cable release for my £20 Sinar Copal shutter last year. The seller thought the shutter was broken, as it didn't work with a normal shutter release.
:eek:Show off lmao.
Every similar cable I have or had with plastic tube covering has parted like that. It's not the plastic, it's the metal spiral tube inside, it's an expanding spring, each use it opens slightly.
I went to mrCad a couple months back when I wanted to take a look at a mamiya rz67 focusing screen. I actually purchased a cloth cable release for £20. I liked it as it was flexible. My current one is stiff and too long. It broke within a two weeks. I have no idea how as I’m very careful with my equipment. I screwed it into the lens, made adjustments and went to take the shot and then it ripped where my plastic cable release has separated. This happened to two more cables prior.
I’ll see what items photographica fair has this month in Victoria London.
I’ll see what items photographica fair has this month in Victoria LoLondon.
That's the way to go imo. Needless to say, give them a very good going over. You'll probably find most will be rubbish!
Avoid anything that looks like it's been made for the amateur market and only buy stuff designed for professional use.
I was watching16 cable releases on eBay, I'd meant to give a heads-up on here. I was just sent an offer and £17 inc £4 postage is a bargain not to be missed.
Hey Ian. Hope you are good
Thanks for the heads up. What make was the cable release?
16 cable releases in total :D A mixed job lot, some heavier plastic covered, others braided metal, one double release, various lengths from 20 - 100cm,
Long cable releases are useful when shooting portraits with a 10x8 camera with longer focal length lenses. I have a 17½" TT&H & a 20" unknown lenses. I have a few front mounting shutters.
