Getting items from abroad has become extremely expensive, so you'd have to add shipping two ways using if using a company Grimes. You could be looking a t $100+ each way now.
With these lenses the aperture is part of the lens barrel or shutter, and the front and rear lens cells screw into the barrel/shutter. So at is a case of having adapter rings made to allow the Nikkor cells to fit the Copal shutter, but I suspect it is easier to fit the cells to a larger Compound or Betax shutter.
Probably the best option is a Sinar Copal shutter, but these have become expensive. Another is a Packard shutter these can be fitted to the rear of a large lens board, some people front mount them, they are still being made, but are easily found second-hand., they are OK for long shutter speeds. They were also made under licence by Dallmeyer here in the UK, Kodak may have exported them to Australia.
Two other options which I use are Thorton Pickard roller blind shutters, although larger ones are harder to find, or I have a large Gitzo single speed leaf shutter, with flash sync. These are front mounting. It's not generally realised that Gitzo made shutters, there can be found on French roll film cameras , but they also made studio shutters, mine would probably be a very tight fit as it's maximin size is 90mm same as the front of a 480mm Apo-Nikkor barrel.
