First outing with the Intrepid 5x4 and Stearman Press sp-445
Hendo'svan
My Intrepid camera arrived last Thursday and my Stearman press on Friday, so I spent a couple of days just getting introduced to the kit. On Sunday I decided to photograph a simple still life on the dining room table, using the large window as a light source. After that I went outside to the back garden and photographed the hut padlock and the house itself. The weather was grey and gusty / drizzly, not the best lighting but this is only a series of outings as I get to know my new kit.
Of the 2 film holders that I loaded I only got to use 3 sheets as one was loaded incorrectly and caught on the dark slide as I was re inserting it, I was a bit annoyed at that, as I have spent the last 6 weeks practising loading them with old sheet film :p
I used FP4 at box speed and developed with Rodinal 1.50, with the Ilford reccomended times and agitation, I found it very easy to load the Stearman film holders, but more trickier getting them in the tank, I kept one empty holder in to begin with to make sure there was no cross loading as per the instructions. Developing was as if I was using my usual Paterson tank, no issues whatsoever, in fact less leaking than I normally get.
The negs where hung on a straightened old wire coathanger with stainless steel clips in a plastic tub with the lid on to keep dust to a minimum, these took around 18 hours to dry completely probably because of the little air movement in the plastic tub.
Do you use a darkbag or darkroom to load your darkslides? I only have access to a darkbag, but I put a cardbaord box inside to give myself a bit of free space in which to move my hands and the film/slides. It's a bit fiddly, but it seems to work. Wet negatives are put in what used to be the airing cupboard but now a home for a wetsuit, tripods and rucksacks. They dry within a few hours with no dust/hairs. I have a couple of old Kodak 5x4 film hangers and some bulldog clips to hang the film.
My apologies for missing this first time round Andrew and well done for producing three smashing shots on the first outing - I suspect there have been a few more since.
I have been using the Stearman tanks almost since day one without any of the issues you read about on the 'net and may I offer you a coupls of tips. After loading the film holders into the tank, run a wet finger tip around the the rubber seal on the tank lid before you press it squarely into place, you will find it will go on easier.
Secondly, never over-fill the tank. You need the full air space above the correct amount of liquid to allow you to squeeze in the sides until the liquid comes up into the filler hole as high as you dare, hold it and then screw on the filler and vent caps. This will create a good negative pressure in the tank and you should not have any leaks.
HI Paul
Yes, I use a big cardboard box with a couple of holes on the side for my arms, I have a darkroom but I'm not convinced it's totally lightproof during the day, hence the cardboard box, maybe I'm been overly paranoid but I don't fancy using the changing bag.
Thanks for the tips Keith, the Stearman Press is a great piece of kit and I haven't had any problems with scratches or uneven development. I have been out a couple of times since, yesterday I managed 1 shot, and waited 40 minutes for the sun to appear for my second, the rain came on and got quite heavy, so I packed up, as soon as I did the sun came out, typical:confused: everything was a bit damp so I didn't bother setting up again, so I'm heading back out today, I shall post my results during the week..
