Help identifying this lens 'control' please!
Tony Miller
Hi everyone, I've recently started seeing a few lenses with these attachments on them.
I think it's something to do with aperture but not sure for definite.
Any help appreciated.
Only the very late Protor Professional shutters, or the Sinar Copal shutters had aperture preview controls. more of the image is needed.
Thanks Ian, the photo is from a current eBay listing which I've included and the other I've seen is from Camley
As I thought that's a lens board designed to be used with one of the Sinar Shutters. They are not something I've used and I think there were different versions.
It's for adjusting the aperture from behind the camera. Useful with close-ups where you won't disturb the set. Much easier to watch the effect of stopping down. A time-saver too. Sometimes called a Mickey Mouse shutter
Thanks @David M - so it doesn't necessarily need a Sinar 'behind the lens' shutter as both the examples here have shutters.
Seems to be the early Sinar Norma system.
Later Sinar offers the DB (Druckblende) system, socalled in germany.
Here you can see a lens fitted in such a shutterless DB corpus, working together with Sinar's behind-the-lens shutter:
The whole system which automatically closes the shutter while bringinging the filmholder to the rear standard is absolutely perfect for studio work.
Btw even this barrelless/shutterless lens cells will fit to a normal Copal shutter.
In my opinion you only will need your own camera and one of it's lens boards - it should be possible to easily change the lens/shutter from one board to the other - if you're not interested in the Mickey Mouse style..
Thanks @Reginald S. - I do have a Sinar Auto Shutter and, in the past when I had a working Sinar camera, I used DB lenses. I have a Chinese-made adaptor which I've modified slightly so the Auto-Shutter works on my Intrepid 8x10 with brass lenses but it's a bit clunky and weighty to take out hiking.
