MPP Micro Technical 4x5 Camera
Flack
I have just bought a MPP Mk VIII 4x5 camera With Schneider 150mm f5.6 Lens. and MPP 6x9 roll film back. The Camera is good condition, It was bought with some known Issues.
I have bought a lot of old camera's in the past and got them working, so I thought I would have a go at this one. One issue was one of the Graflock slider's was jammed, when I stripped it down I found that a spacer was missing, so having a 3d printer I made one and that fixed that problem.
The other was focus rail, all that needed was cleaning and lubricating.
The film back was also not spacing the film out evenly between shots, I took the film holder apart and found a bent rod that engaged in a gear, a quick straighten and it works well now.
Range finder seems to be spot on. I did a test shot with my Instax wide back and all looks good. I just need to shoot some sheet film and the roll film holder now.
I think it could benefit from a brighter screen though.
That Schneider 150mm is a marvelous lens. I have it in its APO incarnation and it does a really fine job.
Yes, a new screen will almost certainly be brighter. You could first try washing the old one.
The original MPP screens are quite dim, as are Graflex screens, a new screen is around 2 stops brighter.
I know some of you have this camera, what is the max lens you can use on this, it came with a 150mm, I have tried my 240mm on it and that focus fine. But when I tried me Super Angulon 90mm I ran out of back movement to focus the lens, I would of thought this lens should work ?.
That's surprising, but I don't know this camera or what it's capable of handling. The manual may be instructive, I don't know:
This article does show it fitted with exactly that lens, so it must be possible:
The MPP Micro Technical cameras need a coned lens board for the 90mm f6.8 Angulon, or f8 Super Angulon, they are rather pricey for the MkVIII.
I think someone makes a 3D printed version, but the finish is poor. This is something I've noticed with quite a few 3D printed items for LF cameras. A friend make Banjos and had some experimental parts 3D printed to test a concept, before making them from wood, they were professionally printed and the finish was superb.
Longest lens would be a small 300mm lens like the Nikkor M f9 300, or a telephoto like the 360mm Tele Xenar or Arton. A regular lens like a 300mm Symmar rear cell won't fit through the front standard
Ian I was looking for a lens board as I only had the one, I could not believe how much they are selling for, I have just made and 3d printed two for myself and they work and look good. I now need to make one for my 90mm.
Thanks for the info.
As you are making your own do you want dimensions, mine's a MkIII to MkVII version, but aside from the slightly different fit they are the same.
Other companies went for recessed lens boards, but not MPP.
Yes Ian that would be good.
Three views of a MkVII 90mm board, however the there are others where the taper continues to the flat base so is wider at the base. It will depend on which 90mm Super Angulon you have.
Ian this is my first attempt will see if it fits and focus is ok, its easier to print this dome design and its stronger this way. Thanks for the image.
Using that style of cone board you can get as wide as 75mm on the MPP, front standard remains on the small rail section inside the body so movements are very difficult. Just don't forget to drop the door down or it will show in shot.
Can someone explain the limitation on the MPP (I've never used one). I am able to use a 65mm with a standard flat lensboard on my Speed Graphic and am wondering what the difference is...
I don't know the Speed Graphic. The MPP has quite a large door and the focus rails are in 2 sections, small piece inside the body and the rest on the door. Even with the door dropped it is only just out of view with the 75mm, never tried my 65mm on one but the chances are you would see the rails in shot.
The Speed Graphic is similar in terms of the focus rail, but the front focus rail drops slightly more than the MPP Micro Technicals. However, the advantages of the MPPs is the back movements when a lens is on the inner rails. Since buying my first 75mm I've not used my 65mm.
One problem with the 65mm is with the aperture wide open for focussing you don't see the end of the front as it's so way out of focus, it intrudes when sopped down to f22, so experience is needed to avoid the rail intruding. With the MPP you can use front backwards tilt and corresponding rear tilt with a 65mm (or 75mm) to avoid getting the front bed (door) in the image.
Ian I notice on the foucus slider there is another bar that you can slide out, it has some measurement's on it in feet, but reading the manual I cant find out how to use it ?. Any idea how?
Not sure which bit you mean, the manual doesn't show the triple extension though.
This is one of my MkIII cameras:
The camera has been restored and recovered since this photo. Strange that the manual has no illustrations of this triple extension.
This is lifter from Flickr, but it's my image anyway. From my MkVII leaflet
Ok Ian I worked out what the rod was, its in the manual, Focus Rail item 22. I now have a good working cone that fits great and is easy to print, only took three attemps. I bet I could use my 65mm lens now, but that stays on my Snapshot now. Thanks for help and advice guys.
