Please Help: Schneider Xenar 4.5 210mm Retaining Ring Size
J
JAMESCF
Guest
I have a Schneider Xenar 4.5 210mm (as shown in the photos) but unfortunately I bought it without a retaining ring! I can't find an appropriately sized retaining ring or any information about what size ring fits this lens, I bought a copal 3 retaining ring but this was slightly too big, as can be seen in the picture the barrel is about 56mm, the threads seem to extend to about 58mm. Does anyone know where I can find an appropriately sized retaining ring (or if it is possible to have one made) or any other solutions.
Any help would be greatly appreciated,
James
It takes a flange not a retaining ring as it's a barrel lens - and not in a #3 Coumpound/Compur shutter. However, it appears that the flange you need is either 60 M9 or 62 M75, most likely the first though as that's what the 210mm f4.5 Componon is in and the barrels are identical.
I have a box of about 60 flanges, as well as a 210mm f4.5 Tessar but made in 1923. Deckel (compur/Compoud) and Gauthier (Prontor/Ibsor etc) changed their shutter mounting threads around 1929, by then the Carl Zeiss Foundation was the major shareholder in both companies. I do have a later 1940 Compound #3 so will see what fits, no promises though as there are so many variations of size and pirch.
No luck, I do have a 62 M75 flange, but that won't fit your lens as it's the same as the Copal #3. It doesn't help that the Deckel #3 shutters were not standard mounting flanges unlike the #00, #0. & #1 shutters.
My 1970 Schneider LF Professional lens review (catagogue) show the 210mm f4.5 Xenar in a #3 shutter with a 58 M75 mounting thread, but the enlarger lens review shows the #3 barrel as 60 M9.
It may be worth a visit to somewhere like MrCad in London, he used to have quite a number of flanges.
Hi Ian,
Thankyou for your advice, this flange business seems even more complicated than I thought! I will swing by MrCad as you suggest as well as trying to find information elsewhere. It might be decidedly less than ideal but I wonder do you have any thoughts on some alternative methods of attaching the lens to a board? I even considered gluing the lens but there isn't much surface area available, perhaps some system of clips hooking onto the front, also less than ideal. One possibility might be to make my own board in two parts to fit tightly around the lens..
Thanks again,
J
I'd ring MrCad first. I have three lenses in Compound #3 shutters and two are the same 60 M9, the other around 64. What surprised me is the 1923 Tessar's shutter is the same mounting thread as my 1954 Tele Xenar's shutter. My other Compound #3 has a larger flange.
I read the Schneider brochure wrong the 58 M75 is the 210mm f4.5 Xenar filter thread, it doesn't mention the mounting thread. Your barrel lens will be the 60 M thread, which is the same as the 210mm Componon enlarger lens barrel.
What camera are you using the Xenar on, what will you use as a shutter?
My historical Schneider literature doesn't give the mounting thread dimensions for the Xenar in barrel mount, only gives the shutter thread mount dimensions. Indeed this seems to be the case for all their lenses available in both barrel and shutter mounts except for the Repro-Clarons (and the enlarging lenses that were available in shutter mounts).
If you can't find a flange that fits, you might be able to have one made here: https://customphototools.com/threaded-rings-for-lens-shutters/
I have not used them but I have seen them mentioned as doing this sort of work on other photographic forums. It is located in Portugal, the proprietor is named Jose Meneses. You will see he has a number of threaded flanges and rings in stock but also does custom work.
David
Jose Meneses prices are very reasonable 20 euros compared to $55 from SK Grimes in the US.
The 210mm Xenar barrel is 60 M.9, exactly the same as the regular Compound #3 shutters, this is the size Jose Meneses lists.
