Rear standard tilt question.
Keith tapscott.
The 5x7 camera I have has front rise, but no other movement on the front standard.
It does have some forward and backward tilt though and some swing movement on the rear standard. I would like to be able to get sharp foreground and background in my photos.
Any advice how to achieve this will be appreciated. I will be using a 210mm lens if that helps.
The larger the format the more important the use of movements, this is because of the longer focal length lenses typically used have less depth of focus even when stopped down to f22. LF lenses are optimsed to geiv ebest results a f22 in terms of overall sharpness.
The best way to get o know a cameras capabilities is set it up on a tripod in front of a table, a patterned cloth might help, with some objects, then use the rear back tilt to try and get eveything on the table sharp on the ground glass screen. Your camera won't have much tilt compared to sme cameras but there should be sufficient.
The main thing to remember is theplane of the back, lens board, and plane of focus must meet at a point, see the illustrations here. Although that's showing ron tilt the result is the same as tilting the camera slightly and using rear tilt.
Swings and tilts are often said to increase depth of field and that is the subjective effect.
In fact, they move the plane of focus to a more useful place in the subject. As Ian says, the plane of the lens-board, the film plane and the plane of sharp focus open and close, rather like a book. Knowing this helps to visualise what’s needed.
Swings work in the same way, but sideways.
If your camera has base tilt, you will need to refocus after tilting.
Rise and fall, and shift (sliding sideways) move the image around on the film, but they don’t affect focus. Mostly used for tall buildings, but there are other uses.
The other thing to remember is that swinging or tilting the rear standard alters the geometry of the image. Not significant for trees, mountains and suchlike, but noticeable with geometric (usually manufactured) objects like buildings or corn-flake boxes. Swinging or tilting the lens doesn’t do this. Too much swing or tilt may possibly mean you exceed the lens’s image circle. It’s not all that common, but the way to check is to look through the cut-off corners of the ground glass to check that you can see the opening of the lens.
You can use all or any of these at the same time, but first set everything to zero and take your time, checking on the ground glass as you go.
When I was first learning to use a view camera, I found this book to be a great starting point:
https://www.amazon.com/View-Camera-Technique-Leslie-Stroebel/dp/1138295531
As @David M notes above, tilting the film plane relative to the lens plane doesn't actually increase DOF, it moves the plane of focus so that both foreground background objects are captured sharply. There are useful YouTube videos to be found on this subject. Just search for "Scheimpflug" or "plane of focus".
Thank you all for your advice. I will have a look on YouTube when I get some spare time. I will need a lot of practice.
I have the original Stroebel book and it’s excellent.
Might I suggest that “…a lot of practice” is your own best advice. When reading textbooks on LF, I found myself reading how to solve problems that I wasn’t clever enough to suffer from. Quite intimidating. Sometimes baffling.
In practice, most shots are relatively straightforward. Sometimes, it’s worth coming out from under the darkcloth and reviewing the situation. If you’re outdoors you may often have to do this anyway, until the light makes up its mind.
Be happy your front standard doesn't have all those movements. Less places to screw things up. Good luck.
