Shutter release cable length?
R
Rob
Guest
Hi all,
Is there a limit to the length of a shutter release cable that remains reliable and is available to purchase?
Is it possible to find a 3-5 metre cable?
Cheers,
Rob
Yes there were long cable releases, I had one but, a friend borrowed it in the 90s, and I've never seen it again :D
Better still are the pneumatic releases, I've picked them up for £1 at a camera fairs in the past. They get listed for silly money on eBay but can be found for around £5 if you are canny. These are typically 6m/20ft but often can be shortened or even lengthened with a little joining piece.
Hi Ian,
Thank you for the reply. They look absolutely perfect, I'm in no rush so will keep my eyes peeled for a deal.
I'm new here and recall reading about being able to donate to the running of the forum, but now can't find the page to do so, could you point me in the right direction?
Cheers,
Rob
I have a pneumatic release. I cut it down to about 300mmin length and find it absolutely great for 35mm and medium format cameras. But it doesn't work with large format lenses. The screw in bit is in a plastic housing which is too fat, so it won't screw in.
Yes, you can adjust the length of the tube, provided you can re-attach it. Some LF shutters are not suitable, because they are too stiff, either because they need servicing or because they just are built that way.
It's quite easy (...and how do I know this?) to accidentally get a very long cable release in the frame. At the moment of exposure, there are often plenty of distractions.
There are little clockwork releases intended to be used as self timers, that come up on eBay from time to time. They might give a useful detachment from camera. The important thing is to keep some slack on the cable at all times, otherwise it acts as a pusher rod.
Plastic-covered releases are much stiffer in winter.
