Some thoughts on light, small, tripods for FF
I'm having an email discussion on hand held LF work, with another member.
When I was living in Turkey I was often shooting where tripods, when not banned I needed a light weight tripod, with temperatures in the high 30ºC ranger and sometimes over 40ºC. On my first visit (2006) I bought a cheap tripod for the equivalent of £7, you can still buy them online for around £15 new, surprisingly far better than the price would indicate, however not small.
So 207 back in the UK I bought a new Slick Sprint Pro II, I paid less than the normal price (too long a story), this weighs 1,065g inc carry bag, max height column raised is 64", it packs down to 19".
Here's the tripod with my Super Graphic. the folded tripod fits into that smallish sports backpack. with the camera, and a TLR, meters, film holders etc. One downside is it has a ball head.
Now to the point that combination is fine (seen above)with no wind or just a gentle breeze, but is too unstable if there are gusts of wind, More recently I've acquired a small Manfrotto tripod for £10, again a ball head, it weighs 1,500g, max height with column 48", packs down to21"
Then earlier this month (the 1st) at a camera fair there was a Slick 444 for £5, now this is solid 1,700g, max height though with geared column extended is 51.5", and packs down to 16.5". and a nice pan and tilt head (fixed). Of the three tripods this tripod is the most stable, the legs open around 6" more when full extended compared to the other Slick, this and greater rigidity makes a big difference. It's downside is it's maximum height but I think I can live with that.
Ian, am I right in thinking that the Slick tripods which you mention are aluminium? If so, then I feel you would be better off with a carbon-fibre tripod. Less vibration. Wrap the leg of an aluminium tripod with your knuckle and it vibrates freely. Do the same to the leg of a carbon tripod and the energy is absorbed. Very little vibration.
I occassionally use a three legged thing Brian with my Intrepid 4x5. The camera is light enough and the built in shutter in the lens means it is fine. I also gently hold the top of the tripod with a finger to aid stability. Probably more stable than using a Pentax 67 with it.
I'm only using these tripods with cameras with leaf shutters Alan,and the Slik Sprint hasn't had vibration issues, the legs though would vibrate with a medium format SLR, particularly without mirror lock. I had that issue with a larger Slik SL-67 Prototype tripod with my Mamiya 645 cameras, until I quickly realised results were actually sharper hand held, using the mirror lock solved the issue.
Ian, the old sherry glass test has convinced me that you even get vibration with leaf shutters - on 5x4. Just taking hold of the cable release can cause vibrations. You sound happy with your aluminium tripods. But I have tried them and am happier with carbon..
If anyone wants to try the sherry glass test, but is unsure what to do, this is how to do it. Pour out a nice glass of sherry. Drink it. Then fill the glass with water, and balance it on top of your large format camera. Fire the shutter and watch the water for vibration ripples.
Joking apart, vibration can be a real problem with large format, and taking steps to stop it can be time-consuming and frustrating. So anyone who wants to stay blissfully ignorant of it should avoid doing the above test.
I am also fond of carbon fiber as travel tripods. The ones available all locally come with terrible ball heads with non-standard camera mounting plates, so I removed that and put an old school three axis head with a tripod scree on top of the new tripod. When traveling, I remove the head and fold the tripod with the legs reversed 180 degrees. This then fits into my TravelPro overhead luggage perfectly and does not have to be carried separately.
I have bought a very nice Manfrotto Carbon Fibre tripod in excellent condition, would have been way over £300 when new. So comparisons of vibrations is interesting compared to my similar sized Manfrotto, Gitzo, & Slick, round tube aluminium tripods which are substantially heavier. The much heavier Aluminium tripods pass you Sherry glass test way better, but that makes sense. they have greater mass.
That's interesting Ian. The aluminium tripods that I have tested had more vibration than my carbon Manfrotto tripod. And when you rap the leg of an aluminium tripod with your knuckle, it does vibrate more than a carbon fibre tripod leg. .... But as long as you are happy, that's the main thing.
Assuming well designed tripods, I think that this has less to do with the material and more to to with the mass of the tripod compared to the mass of the camera.
Though experiment #1:
Imagine you had a tripod that weighed 50kg. I think you likely could mount anything from a 10x8 down to Minox on it have no appreciable vibration beyond that of the camera's own firing and shutter mechanism. And I don't think aluminum vs. carbon fiber would matter in this case.
Though experiment #2:
Imagine you have a very fine tripod, well designed in every way, that weighs 1kg. It's hard to imagine this not being subject to vibration from pretty much any force - wind, the discharge of an SLR as the mirror flips up, vehicles driving nearby. Again, I don't think aluminum vs. carbon fiber would matter a lot.
Obviously, that's hyperbolic. We don't have tripods available as described in #1 (do we?), and I doubt anyone would want to use the one from #2, though they do exist.
At last count I have four tripods and a monopod in various types of construction. My travel 'pod is a carbon fiber item that I keep because it breaks down and fits in my luggage. But it's made - at best - for a DSLR. I've used it with everything up to a 2x3 Speed Graphic and it "works" but care must be taken. It it's windy ... forget it. If the ground is vibrating due to huge water movement or cars ... forget it. Any attempt to raise the center column reduces stability very noticeably.
OTOH, I have two Bogens (Manfrotto). One is a medium sized one that easily acommodates up to 5x4, though raising the center column is dicey. The other one is much heavier with cantilevered legs and a rack and pinion center column and it is rock solid with everything I throw at it. It's just very heavy to trudge around with.
P.S I have nothing that solves the problem of the cross sectional area presented by a very long lens on a view camera. My Wisner Technical has a bellows draw well in excess of 20 inches. Unfortunately, that much bellows hanging in the air just begs for the wind to push the camera around. It requires extraordinary care to get that right. In my case, I deem the effort worth it because I have a 19" APO Artar that I had reshuttered some years ago and the lens is just tack sharp and contrasty.
I used the Novoflex Tripod with the ballhead 3 since about 5 years and thought it's the best solution.
Now with the ebony 45s I use a Novoflex pro 75 with an ballhead 5 and men it's significant clearer and finer what get out of the cam.
Both are carbon and the 75 pro is not to heavy for carry it over the mountains.
I also have a Gitzo "big foot" heavy one but it's too heavy for carrying it so I only use it in my studio with the Sinar F2.
Small and light is nothing for me, using shutter times wit 2 or more seconds it needs to be very stable.
I think a lot depends on the tripod design Alan, as well as the size and weight. I realised the reason for less vibration with my larger Aluminium tripods when you wrap the legs is they are braced to the centre column tube, which is not the case with the carbon fibre Manfrotto I bought yesterday. However I don't see that as an issue, and it's way lighter at 1.7kg than my other similar sized aluminium tripods..
Now I have to decide which head to use with it. I bought a Gitzo R.No4 which is rather large and heavy at 1.9kg, ideal for my 10x8 camera though. I have a smaller Gitzo R.No2 head which is one option.
For what it’s worth, Berlebach publish graphs showing how vibration decays much more quickly in wooden tripods, than in any other material. They are excellent tripods anyway, but because of their construction, a little bulky, if folded size is important.
