Tripod Fitting for Thornton Pickard - parts needed?
LucasP
Hello folks, new here in the realm of large format, and my first post - I am seeking your advice.
I recently acquired a Thornton Pickard large format camera and, separately, a tripod. On the tripod, I can see that the metal fittings look as if they should attach to the base plate of my TP body, but it appears that something is missing.
Would the tripod normally attach to a separate base plate which would be screwed into place, or perhaps to brass rods/studs of some sort which bolt on to the TP fittings? Please see the attached images for clarification.
If rods/stud parts are missing, how would the group name or classify them (for searches online), and can anyone suggest a good source for them?
Apologies for these rather basic questions, I am new to LF cameras and am no engineer! Also, although this item was sold as Thornton Pickard camera, I donlt have a good provenance for it, nor the actual age - any suggestions from those 'in the know' would be welcome.
The clips at the top of the legs would normally spring into the lugs on the turntable. It looks as though you have female fittings on both items. Perhaps this isn't the original tripod? You might be able to add pins to one of them. You might be able to get a more appropriate model on eBay by carefully examining the images posted.
Alternatively, there were Y-shaped adaptors with a centre screw made, which fixed into the camera and enabled a more modern tripod head to be used. You might find one of those. They came in all sizes, so you'd be taking a chance. It would mean being unable fold the camera with the lens in place of course. but you might not be planning to continue using this lens.
Although these legs seem flimsy in the hand, they are surprisingly stable when assembled and in use.
I almost forgot. Welcome.
Thank you David - I'll look into the pins and fitting adaptors.
The tripod is not the original as these were separate purchases.
Are yousure it's a Thornton Pickard camera the tripod ring base is the wrong style. I have just checked my Triple Imperial, as well TP don't use round thumb wheels but while not round isn't the shape TP use..
Some early field cameras did use more modern style tripods even in the 1880's & 90's>the reason for the legs was to allow the camera to be folded with the lens and shutter attached and yes while flimsy on first appearances they are lighter than a tripod and once the camera is set up as David says surprisingly stable.
Hi Ian - I'm unsure of the provenance, so this could easily be a different manufacturer - it was sold as TP, but I'm happy to accept opinions from those better informed than I am; interesting points you make regarding the style of the ring base - I'm still very new at large format; So much to find out and learn.
If you post some photos I may recognise what make it is. Sellers often see Thornton Pickard badges on the shutters and assume the camera was made by them as well.
Many companies sold some of their cameras pre-fitted with a TP shutters, Houghtons for instance sold the Triple Victo with one and a choice of lenses. This version is called a Between Lens shutter by TP themselves, many were sold to fit the front of a lens for retro fitting/
BTW most field camears have double extension, that means the bellows extend twice the typical standard lens focal lenght, a Half Plate camera usually has an 8" (203mm) lens so full bellows extension is roughly 16". With a Triple Extension camera thats more like 24" (600mm).
Beck still make lenses in North Wales but not for normal camera use, they made many RR (Rapid Rectilinear lenses for a variety of companies, they tried hard after WWI with a range of more modern lens designs to compete with better known UK companies like TTH Cooke, Dallmeyer and Ross but never quite suceeded. But in the end they still make lenses :D
This turned up on eBay. It’s the kind of thing that your camera needs.
This is not a recommendation at all. You’d need to make a much more careful study before spending any money. It’s a bit scruffy, but looks restorable. I’d expect to see some sort of carrying strap with it. Can’t comment on the price.
Some have a bit of hinged brass that holds the top part of the legs apart and prevents the legs coming. apologies for the rough photo to illustrate what I mean.
I may see someone on Sunday who often has sets of tripod legs. Last time I bought some it was 3 sets and the total was less than that ebay listing.
Thaks for sending these details - iam keeping an eye out for options, and this is the first tripod that I've seen so far with clerly 'male' adapters on teh legs.
I think that i have worked out a method for attachmentof my current tripod and body - I'll need some long, thin brass bolts, as the legs and tripod mounts all line up nicely, needing only some way to attach them. So, if I cannot find a male-ended tripod, I still have another option.(12.5cm/4.5" witha diameter of 3.5mm/1/8th" approx)
I attach some more images - the lens/shutter does show TP, but the body has a patent reference on it, without further details. I may be able to track it via that?
Well it looks like it is a Thornton Pickard camera perhaps an early Imperial. Those aren't Patent numbers the last TP patent was in 1929 and 338390, theymust be Registered design features. When John Thrnton stated the company beore Pickardjoined his cameras were made by Billcliffe and even after Thornton Pickard began making their own cameras some were still subcontracted.
A side view would be quite helpful.
Hi Ian - I have tried to get some better images of the sides of the camera - I am currnetly a little short of space and the weather hasn't been ideal to shoot outside in the short times available. Here you go, and thank you for all of your feedback!
I have found some sets of tripodlegs at a better price, I'll know more after the 14th July as the seller is going on holiday this weekend.
Unfortunately TP didn't use good material for their bellows, I need to make newones for my Iperal and TwoFoca-Plane Imperial Two Shutter Triple Icamera, unfortunately not the same lenghts so different paterns.
Thanks for these suggestions - I purchased and have had to return a set of legs this week, as they were the wrong fit.
I'll keep my eye out now that I have a better visual reference from the auction in your post, David!
