Tripod irritations.
soupdragon
I am the not so proud owner of a fairly sturdy Benro carbon fiber tripod with Benro geared head.
What I found since ownership is, that with any large format camera mounted, the action of fitting and removing film holders can loosen the thread in the mounting plate.
I do my best to restrain the camera during film loading but it invariably comes undone.
So, is the head unsuitable for large format cameras.
Should I try and source a larger diameter securing screw.
Is it worth me securing the "Arca" style plate using a pair of pliers or the likes?
Do I risk damaging the camera through over tightening the mounting screw?
I found that the materials used to grip the camera base and prevent slippage leaves a lot to be desired with many tripods, when it comes to using them with LF cameras.
I restored three tripod heads earlier this year, I needed new material and found some excellent anti-slip rubber matting on eBay. OK two were quite large old Gitzo heads, but the third was a head from my old Slick Prototype SL-67, the original rubber bit was a lot harder and been lost some years ago.
The new rubber matting I bought is slightly softer, you can tighten down into it and even with the small 6,5cm x 5cm area of the Slick head there's absolutely no chance of my LF cameras moving on it.
What about how tight to do up the screw?
It has a semi circular bit of metal on the underside of the plate. I do this up until my thumb and finger can take no more.
I could tighten it more with a small torque bar or a pair of pliers but am concerned about out damaging the camera.
My small Slick tripod has just that material, however the anti slip rubber I bought is way better, even lightly tightened the camera won't move.
You don't want to over-tighten, you could easily do damage. The issue is the area of contact is relatively small, you just need to use carefully.
Personally, I would say that the base plate is too small, with far too little grip pads.
i use the Manfrotto 410
Probably not much help to you, but I have no problems with mine. My Shen Hao has a 3/8" and a 5/8" thread in the baseplate. I drilled my Benro plate out and fitted a 5/8" hex bolt as you can see. The camera just does not move now.
Confirms ALL my prejudices about quick release tripods.
I used somone's QR Manfrotto last month that seemed to hold really well but it had a different grip system to most I have seen.
I'm always on the look out for non-quick release tripods with bigger mounting surfaces, however battered they look.
The rubber matting Ian uses has improved one of mine a LOT, but it's not QR to begin with.
My Kessler Crane QR baseplate has two screws 1/4" and 3/8" to match the plate on my Chamonix. Using both screws prevent twisting. There are different sizes. I match them up with my Kessler Crane Kwik Release but I think they should fit any Arca Swiss type QR.
https://www.bhphotovideo.com/c/products/quick-release-systems/ci/38005?filters=fct_brand_name:kessler-crane
More easily obtainable in the UK are the Novoflex plates. I have a similar ¼"/ ⅜" QPL2 84mm long plate for my Chamonix.
This is the quickest reference I can find.
It’s a Gitzo head, now out of production. Gitzo made a variety of these in different weights, with different sized platforms and minor changes to the handles. Ben Horne said this was the best head he had ever used, but the long handles were liable to catch on overhanging branches. As you will know, he uses 10x8.
I have two older Gitzo heads both really cheap at my local camera fair, while not the later low profile versions thee largest R No.4 is fantastic for use with a 10x8 camera, the longer control arms are a necessity.
I also have a slightly smaller R.No.2, smaller and a bit lighter, great for 5x4.
He now uses an Arca Swiss C1 Cube with the QuickLink attachments so that the, very expensive, head can be removed whilst out trekking to prevent it catching on undergrowth or rocks, and then quickly reattached when the location has been found. I use a D4 head with the QuickSet Classic release and the QuickLinks so that I can move the head (and a Gitzo gimbal head) quickly between the various tripods I have which are a mixture of Benbo, Gitzo and the latest KingJoy.
Yes, the Cube is staggeringly expensive. More than many cameras when I last looked. Perhaps they are subcontracted to Fabergé.
Any attachment which relies on a single bolt to hold it in place has the potential to rotate. A large head like the Gitzo PL5 will allow several bolts to hold a long Arca compatible clamp on it (it may need washers to give clearance to the clamp but this is not a problem). A long Arca plate can then be fitted to the camera with two bolts if possible, or a long plate with a lip at one end can be fitted so that the lip seats against an area which is solid and again, prevents rotation. Any force applied to a large format camera has the potential to rotate it if it is held using a single bolt holding it to QR plate or tripod head. The answer is to fix it with some form of anti-rotation system as outlined above.
I have the same Benro head and I have found that tightening the bolt with a hex key gets it tight enough to prevent slipping.
A more significant problem was wobble of the whole head, until I found a Youtube video to show how to take off the two blue discs (with angle markings) to locate bolts underneath them. In the process you may spoil the discs but they don't serve much purpose so I've left them off and carry the right hex key with me to allow them to be tightened in the field.
However with the Benro head, the only LF camera I use is an Intrepid; my monorail Horseman camera and my half-plate Kodak go on a bigger tripod with a Manfrotto 029 tripod head. The Kodak is fixed to a Manfrotto hexagonal plate and the Horseman attaches to a long Arca-compatible plate with two screws.
Thanks for all the advice.
I bought the Benro as I like geared heads.
I did own the manfrotto junior geared head but the adjustment knob became very stiff after a short period, to the point of un-useable.
I looked at the cube style solutions but the eye watering prices they command is beyond my reach.
I guess, as I think was mentioned earlier, a second piece of rubber glued to the mounting base of the camera would work.
It's really a matter of sourcing a suitably hard rubber sheet.
I have some brilliant double sided adhesive I use to secure camera leatherette so affixing is not an issue.
Can't say I have ever had the problem with my 4x5. I use a 410 geared head, the adapter plate screw is tighted on with a coin and remains solid. Granted the 410 head is no lightweight but it has done well for the 15+ years that I have owned it.
I have a 410, too. It does need a sturdy (that is, heavy) tripod otherwise the centre if gravity is a bit too high. I think the large area of the QR plate helps greatly with its grip on the camera. My own fear when tightening the screws is that it might damage the camera.
I believe that carefully removing the circular stickers with angle markings makes it possible to gain access to gears and service them.
Look up Dychem Mats. I've never found anything grippier, perfect for removing stuck filters, jar lids and plenty of other uses.
