Wista 45 DX - extended but stuck - any ideas or help?
C A Mendelsohn
Hi there,
Sorry if I use the wrong terminology.
I got my Wista 45dx out today to set up and show a friend.
I haven’t used it for about two months, but it was in full working order, and I am about to start a new project with it.
today - I managed to extend it-( not quite fully) - and then for some reason it won’t retract.
The knob on the rt front just loosens and there is no movement back.
It looks like it has possibly been slightly misaligned in that I can see the gear on one side.
Photo attached .
Does anyone know if this can be fixed? And does anyone know of someone who could do this. I really don’t want to take it apart myself.
Thanks so so much .
Carolyn
Hi Carolyn
Does the locking wheel on the opposite side loosen or is that stuck too ?
One image (the second) does seem to show the misalignment.
You've had similar issues with this camera before, I have a good memory :D It's easy to damage the rack and pinion so this needs careful attention to put right. I have a Wista 45DX myself that has had had heavy use and wear, since I bought it near mint in 1987.
I regularly restore much older Wood & Brass cameras so could probably easily sort this one out. But let me think, look at my own 45DX. I think it's an easy fix. Will PM tomorrow.
Hi there,
Photo attached .
Thanks so so much .
Carolyn
I don't know this camera, but I do have a Wisner which is spiritually a similar camera. On the Wisner, if you extend the rail out too far, the rack and pinon lose contact with each other and the knobs stop working, You have to gently push the rail back in to reestablish rack/pinion contact. I've no idea if an analogous process is possible with the Wista.
Hi, I don't think it has to be taken apart.
I had a Nagaoka with the same construction and there I could move the front standard out of the rails.
Puting it back was quite easy, just bring it in the position where the tooth rail snaps the tooth wheel and turn it gently.
If the first trial doesn't go well try it again.
Good luck
Good luck
Fingers crossed! I love my camera.
There's only one screw for the brass stop that would need to be removed, middle of your 2nd photo, that stops the focus rail racks from coming off the focus pinion when fully extended.
Hi all, it is fixed - thank goodness - I was given the name of a photographer local to me who builds his own large format cameras - made from parts, and he sorted it. There was an issue with the bolt on the right - that kept loosening , he said the cog showing wasn’t an issue really . But middle of the brass knob has a small bolt that kept on coming off and needed completely tightening up. It worked .
Good to rear it;s fixed.
I wish my own Wista 45DX was still in as good condition as yours :D But then nearly 40 years of very heavy use, mostly in the first 20 years, carrying it on a racing bike didn't help. The cog etc showing is quite normal.
My Wista is now semi retired, has been for a few years I have alternative cameras, but my Wista is the most versatile and comes out when I need it.
