Yes, another. "I need help thread"
soupdragon
I have a big camera but cannot find a one bag solution to transporting it.
I'm stuck with packing the tripod separately but, is there a bag, case or wheely thing out there that can accommodate a 8X10 field camera, lens on lens board, film holder, cable release and light meter?
Try looking at a photographer called Shane Dignum. He has a very nice -looking backpack for 10x8, but I don’t know what it is. He’s based in the USA so it might not be available here.
I bought one of these off eBay for my 10x8 when I had one. It was perfect but it's resigned to the loft now.
There's loads of older Lowepro bags which fit the bill, like from the era before they started to over-design stuff and add memory card holders and laptop storage. Look at the ones with names like Photo Trekker and Pro Trekker, the era when most of their bags were either black or forest green cordura. There's loads of them out there. Some of them have a huge front pocket on the main comportment flap which will take some 10x8" holders, and the main compartments are generally the right width for a Tachihara or Deardorff type camera, with enough room for a few lenses and other stuff.
I'm assuming you can also reverse your lens on the Tachihara and fold the camera with the lens in place, hence not needing to store it separately - my Deardorff does this which means you get a lens for free in terms of bag storage.
I use an f64 BPX backpack, very large main section, easliy copes with 10x8.
Well, I bought a slazenger trolley/suitcase/shopping trolley for the princely sum of £11.50.
I intend to modify it with closed cell foam and velcro strips to enable partitioning.
I have one of these small wheelie cases but don’t use it for cameras because of the vibration set up by the little wheels. Suggest you try it out with a few heavy books or shopping before loading up cameras and lenses. Mine is hard, not soft, so the vibration is audible because the case creates a sounding box. You should be able to feel vibration through the handle if it it is bad enough to be a problem.
I realise that I'm a complete dinosaur but when I need to carry my heaviest kit loads I reach for a Karrimor 65-litre walking rucksack which I've had since the 1980s, if I remember correctly. It has a metal frame in the back and a substantial hip belt. It is getting a bit worn in places but I'm sure the metal frame makes a significant different to the load-carrying capability.
On the down side it doesn't have camera-specific padded spaces; but you can create your own padding systems with foam, bubble-wrap etc.
I haven't carried an 8*10 this way because I don't have one but it has been used for a 4x5 monorail and I'm sure there would be enough room for an 8x10.
You could probably buy an old walking rucksack very cheaply and buy more film with the £300 you'd save by not buying a photo-specific backpack.
I've got a variety of walking / climbing / mountaineering rucksacks, and I wouldn't want to use any of 'em as a primary camera bag simply because none of them are designed for quick or easy access. I know some brands do make bags with full panel opening zips that you could put a camera insert into, but in the UK they are few and far between.
People will have their own opinions and tastes on this, but for me I want to be able to put the bag down, unzip the flap and have everything there to hand like a workbench, without having to unpack various bits individually or rifle through subcompartments etc etc. I know we all love the 'large format is slow so embrace it' philosophy but personally I don't want the camera bag be a barrier, or to be inconvenient. I feel like you want to be pouring all your 'slow is good' energy into working the actual image-making side of things.
One good thing about the older LowePro bags, other than being built like brick privvies, is they are widely available for comparatively little money on the likes of ebay and facebook marketplace, because they sold in huge numbers 20yrs ago yet your shooter of the latest Sony vlogging kit and straight-to-youtube drone time-lapses won't be seen dead with a naff-looking camera bag from the 2000s, whereas us shooting the very latest in Victorian tech aren't similarly afflicted. Hence you can pick up a solid bag for your 5x4" or 10x8" field setup for less than the price of a box of film.
Ben Horne has made a few YouTube videos about his backpack choices. He's used them for carrying ArcaSwiss, Intrepid and Chamonix 8" x 10" cameras, as well as all the video equipment. Sadly, the bags he recommends are likely to be US only and, thus, expensive, as the postal costs are now ridiculous.
A Lowepro ProTrekker AW has a huge volume. I would be surprised if you couldnt get the kit you mentioned in it. There is also various loops to attach accessory's too it.
Cheers
Diz
You're right. Some kind of pneumatic wheels are so much better to absorb all the bumps, as well as for off-road use.
There are camera bag trolleys designed specifically for this too.ButeoPhotoGear_Transport_Trolly1_2.jpg
There are camera bag trolleys designed specifically for this too.View attachment 4947
That looks nice.
Does it have a name?
It has the appearance of a Martin. That was a really bad attempt at humour.
I see where you are coming from.
I'm of to the local builders merchants to find sheets of closed cell foam and contact adhesive.
I seem to remember seeing a film that featured Edward Weston using his 10 x 8 camera, and he didn't have much of a bag. He kept the camera on its tripod and simply carried it around on his shoulder.
And his son Brett Weston is supposed to have said about using his own 10 x 8 camera, "If the subject's more than 100 yards from the car, it ain't photogenic."
I've got one of these I use for 10x8 gear. I like it. Saves my back and folds down fairly compact for storage. The wheels come off too.
