Thornton Pickard Lens
I have just been given 2 lenses.
The first one is this Thornton Pickard Recto Planet Lens. The other one I haven't identified as yet.
Does anyone know if this will cover 5x4 before I start to investigate making a lens board.
Depends on the Focal Length of the lens. It's a Beck Rapid Rectilinear lens made for TP.
Tomorrow when it's Sunny measure the FL by focussing the lens on a distant object and projecting the image on a white wall, measure from the aperture ring to the wall. With normal Rapid Rectilinear lenses you need around a little over 6½" FL to cover 5x4 but that varies between manufacturers and some 5x4 cameras had RR lenses up to 8" FL
I have tried to focus with it but so far unsuccessful. The nearest I got to something been in focus was 300mm bellows extension but I was only 5 feet away from the subject.
I will try in the morning when the light is better
I have a Beck Symmetrical lens. It looks just like yours, but the focal length may be different. Mine doesn't have the focal length marked but it is about 8 inches and covers 5x7.
Ian, you won't find anything useful about this lens 'til you take some pictures with it. So why not knock up a quick lens board out of stiff card or hardboard and give it a go? That's what I did with mine.
Presumably, it's about 10 inches, then. Should cover 5x4, but Alan's temporary lensboard seems the best idea. Anything that can stop a photon will do.
I have mentioned before that I once bought am unnamed Victorian half plate camera at a private auction. It had an unnamed brass barrel lens fitted, which looked original. It also came with a Beck Symmetrical brass barrel lens, which had nothing to do with the camera. The camera was unusable so I made temporary lens boards so I could try the lenses out on my 5x4 camera - and also compare them with my 203mm Kodak Ektar lens.
It was obvious when taking the first picture that the brass lenses both had a similar focal length to the 203mm Ektar -8 inches. The pictures showed that the brass lenses were quite sharp, but not as sharp as the Ektar. They were also lower in contrast.
After restoring the old camera I tried the old barrel lenses on it. The pictures were fine, but I am no "old glass" enthusiast, and really preferred the look I got from the Ektar. This is the lens I now use with the old camera, and the barrel lenses lead a very quiet life in a box in the cupboard.
At infinity, the bellows is extended to around 9 inches so I am guessing its a 230mm lens.
I made a quick lens board and just exposed a quick still life and developed it in Diafine. See what happens when its dry
Here's my two Beck RR lenses.
The small one is an 9" Half plate TP Beck lens, the second a 11" Whole plate lens.
The Rectoplanat was sold on Thornton Pickard Imperial cameras around 1912-13 and is not common. The Imperial camera was made in Hal plate and Whole plate sizes. Beck use the term Isoplanat, Biplanat, Double aplanat for some of their RR lenses so it's likely one of these badged for TP.
TP did source lenses from other manufacturers like TTH Cooke ansd others but this is a Beck style barrel.
The small one Ian looks very much like the one I have. Ive cleaned it up best I can, the aperture ring sticks a little when getting close to f/64 but apart from that, the glass looks in very good condition.
The front and presumably rear elements are slightly larger on your lens than mine, but then it's the same when comparing my small TP Beck lens to most other similar FL Rapid Rectilinear lenses.
Beck did sell different RR lenses, some medium priced and others budget the TP Beck Symmetricals/RR lenses were amongst the cheapest lenses available. TP cameras by the 1910's though also came with more expensive modern British lens designs from Beck, Aldis, Ross, Cooke, Dallmeyer and German Goerz Dagors.
So by 1912/13 a budget lens as RR's had been largely replaced in the late 1890's but designs that continued into this Cenury :D
One question I have on this lens. When I removed the rear element, the glass fell out the brass ring. How do you determine which way round the glass goes
The inner side will be concave, the outer convex.
Both my Beck's have screw in retaining rings to hold the rear (& front) elements in place but to cut costs not all lenses have this ring.
I finally made some sliders for an adapter lens board so now I can use my 20"" f8 unnamed Rapid Rectilinear lens on my 10"x8" Agfa Ansco Commercial View or Universal View. Looks great on the Beattie Intenscreen easy snappy focus f8's not so bad at long FL's :D
Early this year I bought a nice late Rodenstock Apo Ronar CL f9 360mm lens for around £20 on a Toyo View lens board (10x8 like a scaled up Super Graphic/Speed Graphic board) as it happens with some grinding it now fits my 12"x10" filed camera as well as the adapter board for the Agfa Ansco's. The 360mm CL was quite and expensive lens when new somewhere around £1000, it's supposedly a dimensionality stable barrel unaffected by temperature changes for critical work. Being a Dialyte it's good from 1:1 (and closer) to Infinity
I have a variety of shutters I can use with these lenses, both now have dedicated TP roller blind shutters, but I've a Gitzo lflash sync leaf shutter, Norka (internal barn door, or the Eyelid :D.
Now I need to decide what to do with my 25" f9 Bausch & Lomb Anastigmat it was another expensive lens when new, covers 20"x16". but inexpensive, unfortunately too long for the 18x24cm Reisekamera I'd earmarked it for.
