home-made 5x4 camera
Lovely looking piece of kit , very well made .
I've not made a complete camera yet , but I've made a few replacement parts . My current project is making a step up back from 7x5 to 10x8 for my Kodak Specialist camera model 2 .
Lovely! One of these days (probably not) I'm going to muster up the necessary ambition to build an ULF camera. I've always thought I'd go with 14x11, but may a bit bigger. I mean...what the heck...if you're going to play... :D
Thanks Alan.
Here's my advice. Go for it! It's easy.
1. Decide on a format.
2. Buy a filmholder, and build the camera round it.
You've got seven days to send us a progress report!
OMG, I can't do anything under that kind of pressure! ;)
Honestly, I've had plans for an ULF camera for many years, but... I know it's best to buy the holder first, then design the camera around it, but I've always been confused by the T-stop measurement. I mean, I know what it is, but how does one get it exactly right such that the ground side of the glass sits in the exact plane of the film when a holder is inserted? I've also been perplexed by the springy hardware needed for the back, but I really like your solution of screw knobs to secure the film holder; definitely going to give that some thought. Btw, did you make your own bellows, too?
You can :D
Took me 2 or 3 days to build my Canada 6x7 field camera. OK I cheated as I used the track bed and front standard of a Quarter Plate Speed Graphic, I had a box full of Graflex parts bought from someone in Paris. I have another track beb amd have managed to make a Siper Graphic front standard fit, a lot of grinding, all the Graflex experts said it couldn't be done. The advantage is a Super Graphic front standard has better movements.
So the new camera is to be 5x4 and 6x17 and must work with a 75mm Super Angulon teh only lens I use for 6x17, the reality is why not 7x5 as well. The other prerequisite is it must take Linhof/Wista lens boards.
I found the T distance really easy when I made my 6x7 field camera, I was lucky though the sections of wood I laminated were well within tolerance. I've made converters to allow modern DDS to be used im Boof orm backs on plate caeras and have never found the T distance a problem.
I know Alan made this camera some years ago. I wonder how he'd approach it now.
Alan,
It sounds like you have given this a fair bit of thought.
You mention the "springy hardware" needed for the back. I did use it on the first large format camera I built many years ago. Then I came up with the design used above. I have used this on four cameras to date, and it works well and is simple to make. The wooden frame that holds the ground-glass has exactly the same dimensions as the filmholder. When you are ready to take the picture you slacken the knobs, remove the wooden frame (try not to drop it in the mud!) and replace it with the filmholder, which can then be locked in place.
You mention the need to get the ground glass surface in the same plane as the film. This isn't too difficult. First measure the T-stop distance on the filmholder. You can do this easily by placing a metal straightedge across the open filmholder, and measuring the gap by sliding a tapered wedge of wood into it until it touches the edge of the straight edge. You can then mark, and measure the thickness of the wooden wedge at this point.
The ground side of the ground glass faces towards the front of the camera and the rebate is at the back. So the depth of wood left should equal the T-stop measurement. There are numerous ways to do this, but the main thing is that the finished result can be checked by placing your straight edge across the inner face of the ground glass frame and sliding the wooden wedge along the ground glass to see if it touches the straight edge at the same point as it did when you first used it on the filmholder.
I hope I'm convincing you that none of this is difficult. I'd be more than happy to be of further assistance if you decide to go ahead.
Thanks Ian and Alan.
I had always planned to use a caliber to measure the T-stop, but I really like your block of wood idea; especially that it can also be used to check the back frame. Did you make your own bellows?
You are convincing me a bit to go ahead, but now that the nicer weather is finally upon us here in the desert southwest I plan to get out as much as possible to photograph. Much more pleasant to hike and photograph when temps are 60-70F vs 110+F! ;)
Alan; good luck with whatever you decide to do.
The bellows - I got these from the Camera Bellows Company many years ago when I made my first camera. When I later made a better one I made a bellows for it and these became spare.
Ian, what would I do different now? I should explain that it isn't a general purpose camera. It was built to do a specific job - photographing the dry valleys in the Yorkshire Wolds. This involves a lot of walking so I specifically needed a very light camera. And it had to be very rigid, because of the winds. I had found there that I could do everything I wanted with a 203mm Ektar lens, so the camera was designed round this. I didn't need a lot of extension as I wouldn't be doing very close-up stuff, and camera movements could be limited to font tilt only.
In practice I have found that the camera works very well. It fits in a normal rucsack. It passes the sherry glass test with flying colours. It is easy to focus. It hardly weighs anything. So I would build another the same if I lost it.
As it happens my photography project in the Wolds didn't happen. I just kept going back to the North York Moors, and across to the coast. The camera has had a lot of use in these places, and I hardly ever use my other, general purpose, cameras with a variety of different lenses. I suppose it has forced me into a very simple direct way of working, which I like. Each to his own, of course.
Many ULF cameras seem to favour simply removing the whole ground glass frame and replacing it with the film holder. That springy hardware is the LF equivalent of a motor drive on miniature cameras. What it does is to speed things up a bit. Not often a problem with ULF.
I was going to mention that digital callipers are very cheap today, but the wedge idea is wonderful. I second the idea of beginning with the film holder. If you are thinking of making your own film holders, they may look simple, but are much more complex that they seem. Even Intrepid failed.
On way to get the register of the ground glass exactly right would be to make the rebate very slightly too deep and then shim it out until it is spot on. Different weights of paper, cut into narrow strips will do this perfectly. Much easier than trying to deepen the rebate by a small amount.
Another curiosity of ULF is that that the cameras seem, in general, to have fewer movements built in. You'd think that every scrap of adjustment would be desirable.
Best of luck.
Alan, I really like the design of your camera, simple, robust and well made. I've had a similar project for some time, mainly as a design/woodwork project, as I know very little about LF cameras. I think you have just solved my camera back problem, I like your idea and no springy brass work. If I may ask a question, what material did you use to make the bellows? I've thought about buying some but I would really like to make the whole camera.
Richard, thank you for your comments. I didn't make the bellows. I just happened to have them lying around and they were the right size. But I have made several bellows, for other diy cameras, so here is what I have discovered. As you will know there are three layers to a bellows; the outer layer, a middle layer of strips of thin card or thick paper with gaps between them where the bellows fold, and a inner layer which covers these strips. The inner layer needn't be light-tight, but it should be as thin as possible to retain flexibility, matte black to cut down flare and lint free to cut down dust. You should be easily able to find something suitable in a shop that sells cloth. The outer layer is more problematical. It should be thin, light-tight, and be a material that the paper strips can be stuck to. It should also look good, of course. I once made a bellows from leather. They look great! But finding a big enough sheet of thin leather might be hard; and expensive. I have made the outer layer of several bellows from some nice cloth I got from Dunelm, the curtain material chain store. This looked a bit like suede, came in different colours, and was light tight. If you can find a local Dunelm I'm sure you will find something useful. And you can't beat handling the goods before you buy!
Ian Grant told me he used bookbinders bookcloth. Ratchfords of Stockport sell this in a wide variety of colours. They also list a reconstituted leather material which is quite thin. I keep meaning to try to get a sample. If you had the inner material, you could stick a small piece to a sample of bookcloth or bookleather to check for light tightness.
You say you know little about large format cameras, so you may not be aware that bellows need to be flexible if used with a wide-angle lens. A 90mm lens on a 5x4 camera is about the same as a 28mm on a 35mm camera. A wide angle. To focus on infinity the distance from the lens to the film should be 90mm. Some of this gap will be taken up by the front and back frames of the camera. So the bellows could be compressed into a gap of only about 50 mm. So far no problem. Now try to use the rising front, or front tilt. If the bellows are made from thick, rigid material, they may not move. A 72mm wide angle lens causes even more problems. This is why bellows are often removeable, so you can replace them with a more flexible bag-bellows when using a wide-angle lens. Just something for you to consider. One solution to this complication is to emulate John Blakemore and use only one lens! - a 180mm.
Good luck with your project. There are other people here who can help, so don't be hesitant about asking.
Thanks Alan, very helpful. Ratchfords sell a number of materials which may work for making bellows. I normally use a standard lens, plus a wide angle of 35mm equivalent. Most of my work is landscape in medium format, the idea of a simple camera with front tilt and sheet film for occasional use without spending a lot of money is appealing.
Ideally you need rise and fall as well as tilt so you can keep within the lenses image circle. Alan's 203mm f7.7 Ektar is in fact designed for Half Plate or 7x5 with modest movements, so way more coverage than needed for 5x4. The downside to the lens is most are in Epsilon or Prontor shutters with no preview lever so you have to set to B and use a locking cable release to focus. The last British made ones were in a Compur #0 but they are quite rare, as are the late US ones in a Compur #1 - I have one and the preview lever makes it faster to work with.
5x4 cameras can be found quite cheap - if you're lucky, but there's something satisfying about making your own.
The equivalent of a 35mm lens on a 35mm camera would be a 110mm but a 120mm is a nice compromise. You can sometimes find 120mm f6.8 Angulons for a good price, I bought mine from Romania a couple of years ago for £90, it's near mint and very sharp and also small and light. It's actually a 7x5 WA lens but great on 5x4.
Be aware the Angulons are a reverse Dagor design and quite different to Super Angulons, the 120 and 121 Super Agulons are quite large and just cover 10x8, as are more modern 110mm WA lenses.
Personally my main lens sets are 90mm, 150mm, and 210mm (or 203mm) but I have a 65mm Super Angulon that I've not used for some years and now prefer a 75mm Super Angulon when I know a 90mm is't wide enough, I do still carry the 65mm occasionally as it has been a life-saver allowing images I couldn't make otherwise.
Yep, the 120 Super Angulon is pretty large and kinda heavy (certainly when compared to the 120 Angulon), but is by far my favorite lens for 5x4. I've owned the 120 SA for 40 years and will absolutely never part with it.
Thanks Alan.
Would you be so kind to recommend where I could buy a filmholder?
Hello Konrad. Welcome to the forum.
5 x 4 film holders are widely available - just do a google search. Alternatively, Ian Grant, of this forum, will probably sell you one.
