Prontor Professional 1S shutter
M
Martin
Guest
Good Evening,
I've just acquired a Prontor Professional 1S shutter (fitted to a Symmar 180mm f5.6) and wondered on the correct usage of the twin shutter release (got one arriving soon). Pardon my ignorance with this shutter but is there a specific methodology of using the twin cable to use the lens in preview for focusing and for firing the shutter? Many thanks.
These shutters aren't very common. Not sure I've seen one in the flesh for sale and I've seen thousands of LF lenses. They were quite expensive, by then Prontor was part of Zeiss and had also taken over Compur but they couldn't compete with Copal who's shutters were much cheaper and less complex. I did see them at trade shows
One cable release opens the shutter to full aperture, white socket. They supposedly have the least vibration of any LF shutter.
From a technical point of view Prontor Professional shutters probably belong the most versatile shutter systems you can get. One cable release opens the aperture, acting as a preview (you may preview the photo with your working aperture, or fully open). The other cable release is actually for shooting. You'll see that when pushing each release button.
Also there are different kind of cable releases for the Prontor. A very useful one is the "Central shutter release cable" , with which you may take full advantage of the Prontor shutter system, as you can chose between 3 positions of the mechanism:
1. Aperture fully open for groundglass observation at maximum brightness, shutter release locked
2. Preselected working aperture for depth of field control, shutter release locked
3. Shutter closed, preselected working aperture (pre-selected f-stop), shutter ready to release
You can find these shutters between £50 - £80 on Ebay. Here is just one example (it looks a bit cumbersome and heavy but really isn't):
