- Aug 29, 2020
For the past month or so - as noted here - I've been fiddling with Pyrocat-HD in a variety of ways. The input from a number of you here has been invaluable and much appreciated. For now, I am sticking with Agpapan APX 5x4 which has been my standard film for many decades and of which I have a considerable pile in the freezer. I suspect other film like Tri-X or TMAX-100 may show greater edge effects, but I want to control one variable at a time for the moment. This is hampered somewhat insofar as my densitometer only works with conventional negatives and cannot account for the stain, so I am just "eyeballing" it.
First, some observations:
And now some questions, if I may:
As always, I appreciate those taking time to answer my silly questions ...
- When processing "conventionally" (in my case with hangers in 2l rubber tanks) Pyrocat responds very much like PMK in terms of time, albeit with less frequent agitations required.
- It seems that N+ and N- processing will work about the same as other developers when using Pyrocat normally. i.e., One can increase or decrease development time according to the SBR of the negative. This is an improvement over PMK which oxidises so fast that significant N+ requires me to have a second bath ready to mix for the extended times.
- The FB+B for Pyrocat is notably better viz PMK, however Pyrocat seems to have nowhere near the compensating effects in the highlights as does PMK.
- Pyrocat seems to despise overexposure, especially with stand processing. This is quite the opposite of most other developers I have used and I'm still adjusting.
- I am still "fiddling" to find the right ASA to use. I ordinarily use ASA 50 for this film. It's beginning to look like ASA 80 may be more the right choice for normal Pyrocat processes and ASA 100 (box speed) for stand processing.
- There is some debate in the literature as to whether lowest shadow detail should be placed on Zone II or III. What is your collective practice in this matter?
- There is some variability in the literature as to what the recommended frequency of agitation should be for semi/stand processing ought to be. Many suggest dividing total development time in 3 or even 4 periods, each of which enjoys a brief agitation. I found that with both 30min and 60 min total times, a single agitation at the halfway point produced strong negatives. I guess my question is what the tradeoffs are for more-or-less agitations during very long development like this.
- What dilutions have people tried for doing stand/semi-stand and to what effect?
- What most affects creation of edge effects? Dilution? Agitation (in)frequency? Other?
- It's clear that semi/stand is useful for to expand the midtones in a short SBR scene. What is unclear to me is how semi/stand is to be used for very long SBRs. Steve Sherman seems to suggest that one wants lower than usual highlights so that split printing can be used to raise contrast primarily using only the hard light. Do long SBRs also mandate higher stand dilutions?
