Building my first full camera ...
Marley's Ghost
Well as the saying goes ... here goes nothing: while I'm having huge fun taking 5x7 images with my antique tailboard travel camera ... I'm missing some of the refinements I take for granted on my MPP 5x4 - movements for one! I intend to let the travel camera be my portrait standby ... but build a more refined 5x7 for landscape etc.
My general requirements are:
1. Lots of extension as I am very fond of closeup work.
2. Reasonable weight as I suffer from back issues.
3. Not plywood: I really admire Intrepid for their work in making reasonably priced cameras, but I bloody hate plywood!
I'm super lucky in that I'm self employed and I have a pretty well equipped workshop unit to use, and that though I'm not a qualified mechanical engineer - both my grandfather and father were, and I learned to file properly flat before I was five!
My first task is the overall design, which is going to some degree be determined by the bellows. I have a large quantity of bellows cloth turning up next week and my first task will be to build what is really the heart of the camera.
The focusing mechanism I may well base on the chaps at Intrepid's brilliant wheeze in using off the shelf CNC machine parts: linear bearing sliders for baseboard extension and a 'ball screw' for focus adjustment.
My use of rare earth magnets in my day-job means I will probably use these a lot in the build: for example in creating 'zero stops' on the movements, and even for securing the spring back.
Watch this space :)
Excellent.
This sounds like the kind of thing we’d all like to see regular illustrated reports on. (Mistakes and all, please - fallibility is very dear to my own heart.)
Excellent.
Well I shall be filming for my YouTube channel and taking stills for here ... busy busy :)
Having trouble working out what wood to use in the main components. The quality of mahogany available today is awful, and much as I adore the look of Edwardian cameras I think walnut may be a better bet ... but then again I may go for something really exotic. My job sees me dealing with musical instrument makers all the time, so I may try zebra wood or purpleheart. I may even go blonde and use flamed maple.
What woods did nice Mr Stradivarius use?
He used flamed maple for just about everything except the violin front which was Alpine spruce. Spruce would be just about the worst wood to use for a camera. It is used on string instrument fronts because it vibrates very readily. The last thing you want on a camera...
Marley, I may have misunderstood you but I am not sure why you are designing the camera round the bellows. For the cameras I have designed and made I have started with the filmholder and designed the back round it. Then everything else follows on. And I don't want to try to teach anyone to suck eggs, but you need to keep in mind the problems with flare. I got this on a Victorian field camera. Stray light was bouncing off the inside of the bellows, reflecting off the inner face of the wooden back frame, and ending up on the film. I have tried to overcome this potential problem in the design of the back on the next camera I am planning on making.
Incidentally, good mahogany is still available. Try David Dyke Luthier Supplies. You might also look at Spanish Cedar, the preferred wood for classical guitar necks. Lighter in colour than Mahogany. Lighter in weight to, but equally stiff.
Good luck.
Yes, indeed, the film holder is the basis for all other dimensions. Perhaps the construction of the bellows is the most unfamiliar problem, which needs to be solved first.
Good luck.
Very familiar with David Dyke ... I own a company that build parts for electric guitars and basses. :)
The reason I'm starting the design around the bellows is I already built a 5x7 spring back which is working very successfully on my other 5x7 camera so there is no 'design' needed for that, I shall simply build another one - it's all programmed into my CNC laser cutting gear. The back design gives me my rear standard size and thus the bellows rear dimensions but the baseboard and focusing mechanism, and indeed the way I get it to fold will be dependant on what fits with the extra long bellows extension. I think it will be easier to work out how to get the camera to fold into the most compact package possible if I know exactly how large my bellows will be folded. To know that I have to make it first.
Re flare from the inside of the bellows bouncing off the inner face of the wooden back frame ... well, I will be using a traditional triple layer bellows with a matt black cotton liner, so that should help. As far as the back board goes, if I get any reflections I will consider laser etching the wood surface before re painting matt black. Laser etching will ensure a knurled surface that breaks up reflection.
The other reason I want to get the bellows making over right at the beginning of the project is that although I've made a couple of sets of bellows before, it was when I was in my teens, and thus a long time ago. In my past experience It's more challenging to get a set of bellows looking professional than a camera body made of wood and brass etc. On a bellows, if I get a fold 'wrong' or the bellows has a 'twist' I'm going to have to look at it for as long as I use the camera.
I look forward to seeing pictures of your progress .
+1 to follow your progress and see the final video. I am a fan of the colour of cherry wood as I did consider doing my kitchen in it, till the costing part of the sale.
I grasped the nettle and built the bellows for the new 5x7 project on Saturday. There will be a full video episode on my channel about the whole process later this week, but I have to say it was nowhere as difficult as I thought - or indeed as I remembered from making a couple of sets of bellows as a teen. True I now have probably the ultimate bellows making tool - a laser cutter - and ten years of running a small enginearing company to help as well :)
Very handsome. Is this the birth of a new business?
I can't say I haven't thought about it :)
Lets just say, for the moment I'm happy to be creating something I want for my own amusement - and my YouTube viewers.
I'm delighted to share any technical info etc I pick up as I undertake this project here mind.
You can see the bellows build video here
here are some taster photos
