Replacement cable release socket
Darrin
Last question for today, does anyone know of a way to replace a lost cable release socket on a Compur shutter. I have a couple like this that are in perfect condition except for no cable release socket. No such thing as spares on the interweb :(
InkedXenar_LI.jpg:(
On mine, I am able to threat a release directly into that hole - at least on some shutters.
If I cant find any other way I might have to resort to that.
A small nut, preferably brass, might work. Something with the same pitch, that the end of the cable release will jam into. You might need to do a li0ttle work with a needle file…
Then, heart in mouth and Araldite. You might want to mask the speed ring while you do this.
A dab of matching black paint for appearances.
Be careful. If it is not threaded for a release, attempting to screw one in could result in brass shavings getting into the shutter mechanism.
There was no standard for cable releases and so they have tapered threads to fit slightly different sizes. The shutter releases have straight threads, I regularly tap the release arms of older shutters, I can't remember the metric tap size off hand and it's ,arkings have worn off :D
Yes, it was a last ditch piece of advice to be taken with caution. It might reduce the resale value of the lens too.
Linhof sell adaptors, but they are for Copal shutters, which are quite different. They are sideways.
They may be able to help with yours, but I don’t know.
If you do succeed in making a new one, you might find others in the LF community who’d be willing to pay good money.
