Re-assessing my LF gear
D
dsmith
Guest
Hi All
I am in the process of downsizing my LF equipment. I am looking to make it much more portable than my 10x8 and 12x20 set-up which no longer work for my shooting style.
I am looking at cameras like the Wista 45VX/SP. Horseman 45FA or Toyo 45A. I have also considered the Alvandi 4x5 but I don't like the set up that uses those cones, it just becomes too expensive and too cumbersome to have more than one lens! I do like the Chroma Snapshot camera for its method of interchanging lenses, but am not keen on 3D printed camera bodies.
I shoot a wide variety of subjects and have a strong preference for wide angle aesthetic (though do shoot longer FL as well)
Having just found this forum I thought it might be useful to check out what cameras you all might suggest thinking about
Dave
Hi Dave,
I presume your ultra-large format photography set up has been mostly for contact printing whereas 5x4 inch will be for enlarger made prints?
One of the advantages of the smaller 4x5 inch format is the lightness (relative) compared to ULF. Not sure how a heavy Wista VX/SP models like the Linfhof Technica, MPP VIIs, which are all very sturdy, bulky, well-built cameras adding weight and inconvenience, offer anything more than your pre-existing 10x20 inch format camera and 8x10 inch.
If you enjoy the wide-angle perspective, why not go ultra-light and fast for LF?
The use of LF movements with the exception of vertical shift and cross shift are mostly redundant: nothing we do ever throws the depth of field of an ultra wide angle lens out of focus before the image circle of the lens expires. The fixed rigid ultra light set-up wide-angle LFs from Argentum, Walker and Silvestri (no need to ressurect the rear standard plane parallel for ever shot) makes a modern technical camera with dedicated wide-angle lenses a dream to work with or undertake street work with. The Alvandi never impressed for its rigidity on paper although I've never used one.
I'm fond of both the Walker Titan XL and the more obscure Silvestri Hermes series cameras with built in viewfinder (no need to focus ground glass); built in lens helicoids (for zone focussing). The Walker Titan XL has the advantage of using more lenses whereas the Silvestri requires helicoid mounting for each focal length. You can see how it is not much larger width wise than a 35mm rangefinder camera - much taller but easy to carry due to its ergonomic shape.
Dave the Graflex/Toyo Super Graphic is quite a ligh but sturdy camera, I was looking for a Toyo 45Awhich used to be quite cheap 14 or15 years ago and then a Super Graphic was listed on 2 or 3 Forums so I bought it. I needed a camera for hand held LF work which isn't possible with my Wista 45DX.
While the Super Graphic doesn't have as wide a range of movements of my Wista I've never had problems it has enough for my work.
Unfortunately there's fewer LF cameras for sale now in the UK compared to 15 to 20 years ago,
Hi
Hi Dave,
Hi Dave,
Hi RJ
Thanks for that, it is much appreciated. I do really like those technical cameras, the Silvestri is a great looking camera with amazing engineering. Unfortunately, it is pretty difficult to find the various accessories these days even if you can find the camera! Whilst I like the idea of run and gun with LF I do also make portraits so an exclusively wide angle camera is a bit impractical. I am not keen on those folding wooden cameras like the Shen Hao, Chamonix etc. If I could find a Cambo Wide with more than one lens that might work, or a Silvestri with the spacers for say a 135 as well as the 47 would also be ideal
Dave
Dave
Hi Ian
Thanks for your help with this. I agree, not much option for LF gear these days, especially those technical style cameras. I have considered the Graflex cameras, but it is difficult to find one in decent condition these days. I think this is going to be a very difficult transition to be honest. I am hedging to the Wista 45SP/VX but it is by no means ideal. I do like the Cambo Wide or Silvestri cameras, but they don't seem useful for portraiture.
Dave
