Whish me Luck
Flack
Well I am all setup ready for my first shoot with LF Camera and my Formapan 100, just need to get out and test it all, lots to learn,one thing I notice is when I use my loupe, its the same one as I view my 6x6 negs with, I have to hold it about 25mm off the ground glass to see sharp focus instead directly on the glass, is this ok?.
Yes, that's fine. Just remember to tame it's contrast you need to shoot Fomapan 100 at 50EI and the development time needs to be shorter than other brands.
Is it a loupe with clear sides like this: https://en.wikipedia.org/wiki/Loupe#/media/File:Magnifying_glass_20101113.jpg
I have the same thing for using on a lightbox, my chum told me to get one with black casing for using on a GG more like this:
New ones area bit more dough, I managed to get an eBay one for £20 but it was a revelation.
Do you have any figures to share, based on developing in Stearman Press SP-445 tank please?
12 mins at 1+1 to 100, intermittent agitation, that's a starting point.
The opaque-skirted loupe is for examining self-illuminated images, like a ground glass, to prevent outside light interfering with the image. All very sensible, but with an LF camera, you will be excluding external light with your dark cloth. A transparent skirt, or even a completely open device like a linen tester, should work perfectly well. If you don’t use a dark cloth, you need the opaque model. It will do no harm to have one, even if you do. They might be a little more robust. For full disclosure, I use an opaque one.
