As usual I have no idea where to post this...
moggi1964
but here we go anyway.
So I am almost complete in my 'restoration' (too strong a word for what I have done) of the half plate camera. I have given the bellows a single coat of acrlic paint and they will soon get a second. The brass and mahogany have been cleaned up and Ian added the final touches to the GG (it's the most credit I am going to afford you Ian :)). He is also rejuvenating my shutter.
I tested the use of a sheet of half plate film on a half plate glass and found that it is kept very flat. So my plan is to get some glass cut to the right size and use it to hold the film in place in the film holder. We will see what we get!
If all goes to plan, first shots next weekend unless this bloody rain doesn't cease :rolleyes:
I still don't have a developing option so that part will need to wait. For now!
All sounds great :)
Obviously I don't know your budget, but I bit the bullet and bought a Stearman Press universal daylight 'tank'. This handles 5x4, 7x5 and even 10x8 - both negatives and plates! I actually find it easier to load and work with than the 5x4 only version. It kinda future proofs my work, as I may well wind up shooting 10x8 if a suitable camera comes up at the right price (I already shoot 5x4 and 5x7).
The elephant in the room is that it's around the £200 mark, which is a lot for a plastic doohickey - but it's well made, and with a bit of looking after should last many years. It doesn't even have the plastic O rings to wear out and leak like the 5x4 version, and speaking of leaking ... it's the only dev solution I have used that I can use without gloves - as it all up 'can't leak' because of its design. Oh it's easy do dry out quick if you are doing batches of film one after the other too.
Marley,
I have seen that system and it is on my list of things for the future. I love the enclosed environment which would be a bonus given the small space I am likely to end up working in when developing. I know what you mean about the cost but when something works then i guess it doesn't matter if it is made of plastic or carbon fibre so long as it works.
I especially like that it does the plates as I do intend to bring plates into my arsenal of photographic media.
In terms of the volume of chemicals you use, how does it compare to developing the same amount of film in trays?
I have so much to learn and it would be easy to throw a fair amount of money at it so I am doing my best to not do that. That isn't to say I don't appreciate the advice on things I might use, I truly do which is why I have the LOTFTF. So please, keep them coming.
It’s basically a tray with a lid, so it should use much the same quantities. Some people like to use a good deal more liquid, for reasons that seem good to them. Very highly diluted developers might need more liquid to avoid consuming all the reagents.
But, as they say: “When all else fails, read the instructions.”
Just out of curiosity, would it be practical to stack a second one on top of the first and agitate them together? It would greatly speed up processing a batch. You’d need to fill and empty them with, say, a thirty-second interval.
It uses 500mm of solution for any 'load'. either four 5x4, two 5x7 or one x10x8 - about the same as I'd use in a tray. I don't think 'stacking' is practical as you have no way to shuffle the film for even development. I only take about six minutes to dry my tank with kitchen paper and a warm hairdryer, so a couple of 'loads' an hour is possible with reasonable developing time.
I ordered a Stearman Press SP 445 today, I have read lot's of great reviews on it and I really like the idea of developing with the lights on as thats what I'm used to, I also got a text from DHL to tell me my Intrepid 5x4 is arriving tomorrow :)
I have both the Universal and the 445 ... and have done loads with both. A tip for the 445 is to get a bit of board and two strips of 24mm square timber and screw them to the board so that the base of the 445 sits neatly between. The 445 is very narrow based and very tall and falls over super easily, so a 'stand' is hugely useful ... especially when loading it.
Thanks for the tip, I shall make one when it arrives.
I won't pretend that loading the drop in film holders in the 445 isn't a tad challenging. It's a bit too easy to put one of the film holders diagonally and thus block the second from loading properly. 20220216_210514540_iOS.jpeg
How it's meant to go
accidental 'cross loading'
easy to do in the pitch dark :)
I have 4 old sheets of film, I shall practice loading with my eyes closed as I have been doing with my film holders.
Yes, the spaces on the 445 are rather close together and it’s easy to cross thread them. Although I’ve constantly been worried about knocking it over, it’s never happened in practice.
Do you shuffle the film inside the 10x8 tank? I had thought the whole point was to use it in the light, without touching the film at all. The Stearman website recommends agitation by lifting the sides in turn. Manual agitation would turn it into a very expensive alternative to a Paterson tray.
I don’t doubt that it can be dried quickly, but there’s still the whole development time to be done again. My worry with stacking would be the top tank sliding off. It might need some little rubber bumpers attaching.
As I said, this is curiosity on my part, inspired by discussions of very long developing times.
No shuffling - the 10x8 has internal, removable dividers for keeping sheets apart ... and once the lid goes on in the dark, it stays on till the wash.
It dries much faster than you'd think as there are very few nooks and crannies to hold water droplets.
That’s what I thought. As agitation is by lifting sides or corners, it seemed possible to stack two tanks, provided they didn’t slip. Expensive, of course, but it would speed up the processing of multiple sheets, particularly with10x8.
Darkslides hold two sheets, so my thinking seems to revert to pairs.
Could you not just bind the 2 tanks together with a couple of large rubber bands?
Hadn’t thought of that. What I had in mind was those little semi-clear self-adhesive silicone bumps that you use for preventing cupboard doors shutting with a loud bang.
Magnets?
