I have just had success my first DR print using my snapshot and the MK2 Enlarger kit. My enlarger only holds up to 6x6 negs so I thought about using my snapshot as the actual enlarger, so here is my results. I could have chose an easier negative to start with but the idea work's the print is a print with no dodging or burning. I also fitted a 90mm enlarger lens, not the camera lens as the Camera lens would not focus at all.
I made loads of different lenghts of 3d printed rods to get it to work, once I found the right lenght of rods to get me an infocus image at around 10x8 size, I then had a mate of mine make them out of some 8mm round aluminium bar.
I made a few lens mounts with my 3d printe, and settled on one about 30mm in lenght, this screws in to the helicoid and then you can use the helicoid for fine focus.
I aslo had to make a bracket to go from the camera to the copy stand, as the 3d printed body mounted tripod screw was flexing making it impossible to fine focus.
The limiting factor is the lenght of the belows of the Snapshot, they are really to short for a good range of heights, but to be honest a 10x8 print from a 5x4 neg is the smallest you/I would want anyway.
Its been fun doing it, and now that I have a working solution I can now fine tune it.
The Intrepid Mk2 Enlarger kit is great, but what would make it even better is if they {Intrepid} would make a 5x4 bellows housing to go with there kit.
