Shutters and aperteurs
Rickystyx
Ok so I bought a lens that is quite nice but the shutter isn't as in it is currently locked solid. it's a Synchro Compur shutter of size 1 so I was wondering if a size 1 copal shutter will do as a replacement I know the threads are the same but the one I've found has no aperteur plate. are they basically the same shutter and would I be able to swap the aperteur plate across from one to the other or is it all more technical than that?
I'd like to get a working shutter for this lens whilst I try to rebuild the originaI, but I might be being a bit thick since I'm rather new to this stuff
Cheers
Richard
The Aperture is related to the Focal Length, so varies, Aperture (F stop) = Focal Length/ Diameter (of the physical opening). I use a spreadsheet to calculate the differences.
There are also Prontor (Press) and some late Ibsor #1 shutters, these are a lot cheaper than a Copal #1. I did pick up a NIB Copal #1 for a decent price before Christmas. Zeiss almalgamated Compur with Prontor, there are some very expensive late Prontors, they have aperture as well as shutter preview.
The other thing to be aware of when replacing a shutter is that the distance between the front and rear element can vary and is often compensated by the use of shims.
Thanks folks I understand the focal ratio and have noted the shim possibility. I've got the original shutter sort of working but it sometimes doesn't cock ready for taking a picture - if I could get that sorted I'd stick with this shutter but I suspect getting the shutter professionally serviced would cost more than I paid for the lens by a long way. I might just keep on excercising it to see if it gets better with use - it is much better than when it arrived.
One very gentle non-invasive way to loosen a shutter is to put it (without the lens cells, of course) in a sealed box with a saucer of some kind of volatile solvent like lighter fuel or meths. Leave it for a few days and it might improve. If the obstruction is accumulated dirt, rather than gungy lubricant, this won’t help much. You may need to be more invasive.
The problem with immersing the shutter in solvent is that although it may free the mechanism, it could also flush dirty oil onto the blades - exactly what you don’t want.
The angular distance between click-stops is the same for all the lens cells that it used, so if you know the maximum aperture, you can devise your own scale. If it doesn’t have stops, it’s possible, with considerable patience and the right tools, to measure the opening as you stop it down to construct one.
Unless you are very highly motivated, there must be a better way.
I've got a quote of £90 for servicing the shutter - it might be worth it as long as the shutter works properly afterwards as I would still have a fairly cheap lens even with that cost - just hits the wallet when I could do without that. Anyone got experience of Cameratiks in Edinburgh?
So read the following with the proviso that there are many ways this can go wrong ...
I have resurrected many shutters simply by cleaning them slightly. They normally need cleaning far more than adjustment unless the mechanism is really ratty.
I use a small (SMALL) drop of naptha on the mechanicals in the shuttter and work the mechanism thereafter. The problem is that you have to do this while avoiding getting the naptha on the shutter or diaphragm blades. This typically involves disassembling the front plate of the shutter to get to the internals whereupon you an surgically apply the naptha. An alternative is to set the shutter on T or lock down B and use a pipe cleaner to drip a small drop of naptha into the shutter mechanism from the inside of the opening.
In all transparency, I've saved more than one shutter by just placing a small bit of naptha into the entryway for the shutter release or around the speed selection dial. The problem is that this pretty much always gets naptha on the shutter/diaphragm blades. So, I have to let it dry and gently wipe off with a lint free lens cleaning cloth or equivalent.
If you decide to try this, do so with the lens elements removed making sure to keep track of any shims or spacers for subsequent reassembly.
My father used to 'sweat' shutters in heated boxes with little dishes of carbon tetrachloride ... a wonderful degreasing agent ... of course this was before we all realised CCl₄ is toxic to liver and kidneys and brings you out in galloping cancer.
I have taken the cowards way out with this one - although I got it so that it generally operates it wasn't at all consistant so it's off on a holiday to bonny Scotland in the hope that it will come back working properly. I can only hope
Carbon-tet was wonderful stuf!
Nearest replacement i've found is brake and clutch cleaner which you can buy in 1litre tins or spray cans.
I've used it to clean shutter mechanisms out, once the aperture and shutter leaves have been removed, though it works so well that you need to re-lube the pivots and bearings afterwards.
If you know the secret of how to get a hit-free wallet from time to time, please share it.
Scottish engineers can get the Starship Enterprise going again, so a shutter should be child’s play.
I used to like the smell of carbon tet. I did work really well.
The great Scottish engineers James Nasmyth and James Watt immediately come to mind along with the Canadian born (later American citizen) Elijah McCoy who got his engineering education in Scotland. So carrying this tradition forward, shutter repair should be child's play for the Scots.
As an FYI I see Linhof & Studio also offers service for "most" medium and large format shutters: https://www.linhofstudio.com/large-and-medium-format-camera-servicing/
David
When my father worked for British Hovercraft in the 70s they used to wash out the fuel tanks with carbon tet before doing repair work on them (which involved folks climbing into the giant fuel tanks in person) - as you can imagine the guys who worked in the tanks suffered somewhat.
I’ve used Linhof for shutter repairs and been entirely happy.
Well the shutter can't have been all that bad it's in the post and on its way back - That was a very quick turn around since they didn't get it until Tuesday. Hopefully it will come back fully functional and I'll still have what I consider a bargain for what I've paid out. I know it might not be everyone's choice for a lens but it will get me going along with my 90mm wide angle. I'll give it a go when the shutter arrives. Tomorrow I'm hoping to take my first ever large format Photos - if I remember how to make everything work as it should
Don’t worry. Everybody (yes, everybody) loses track of the process from time to time. No single step is difficult, but it’s notoriously easy slide past one of them occasionally.
Best of luck. It will get better.
I've written out a workflow which I will follow then no doubt I'll need to add the bits that I've forgotten. I've always wanted to have a large format camera since I was young but of course they were always out of my budget and I was convinced that it would all be too difficult - I'm aout to find out if I was correct.
It isn’t difficult, although it can be made so. It makes you slow down,
One famous writer was very proud of how fast he could get his kit out of the car, unfolded, erected and ready to shoot. No doubt it made him happy, but the rest of us can take our time. Your camera is your friend and we don’t tell our friends to hurry.
Leave placeholders in your workflow for profanity ...
Good advice, but try to stay calm, too. Remember, the most important adjustment is the direction you point the camera. If that’s OK, you can forgive yourself for a tiny bit of clumsiness.
If you’ve been reading textbooks, they can make things sound very complicated, but you’ll be fine.
