Darkroom Hit 41 Degrees
With possibly higher tempertures tomorrow, how concerned would you be about the developers in there.
I have started to put all the bottles into a plastic box filled with tap water and Ice blocks and put he box on the cold slab in the pantry
Not remotely, I lived in Turkey where it was hotter, store at ground level, that's a lot cooler.Never went over above 22-23ºC when it was over 40ºC outside.
Make sure paper and film is removed from your darkroom. They will be affected far more.
I'd be more worried with developers like 510 Pyro in a cold darkroom here in the UK, unusable.
On Radio 4 this morning, the prediction was the hottest part of the UK would probably be Doncaster . .. . . .
