A New lens
Flack
Just thinking out loud here and open to any advise.
I have just got hold of a F8 75mm Copal 00 Super Angulon, it says Made in Germany on the chrome lens surround and Technika on the lens ring, not sure what shutter it has but it says Linhoff on the lens barrel no mention of Compur.
I have searched on the net and found plenty of this type of lens, but not this exact one, the levers and lens ring are not the same as any I have found.
Does anybody have any info or ideas about this lens. It has not got a lever to focus wide open you have to set it to bulb mode and use the cable release.
I have just been setting it up to use it on my snapshot 4x5 and have had to experiment with the FFD and getting the lens to focus through out the range, I think I have it now, I made and printed off some lens bars that mount the front standard to the rear standard to be able to focus using the helical, so I need to shoot of a couple of test sheets of formapan to try it out.
I tried it on my 4x5 Intrepid Mk4 but could not get it to focus using the pre lens hols on the focus slider, I thought about making and printing a inset lens board, but it would be very difficult to attach the cable release as its quite a small lens, the lens mounting hole is only 26.3mm. I did make an adapter plate that used the pre lens holes on the focus slider to move the front standard rearward that allowed full movement, but then decided to use on my snapshot, as I mainly try and use my snapshot for night shots and distance focus, so this setup would be good for that and to leave it on this camera permanently . A 3d printer is great for this type of fiddling.
Some Linhof selected lenses were in slightly modified Compur shutters. Zeiss, B&L, Gauthier (Prontor) and others wer shareholders in Deckel who made the Compur, one of them was also a major shareholder in Linhof.
Copal never made a #00 shutter, my 75mm f8 Super Angulon is in a Compur #0 but earlier 65mm, 75mm & 90mm f8 Super Angulons were in the smaller Compur #00, it has no preview lever, or T setting, so you have to use B and a locking cable release for focussing.
You can get a 90º piece that goes between the cable release and lens to allow easier use with a recessed lens board. According to interepid your 75mm should be compaible.
I can’t comment on the provenance of your lens but regarding the Intrepid, I have the black version. As Ian mentioned, a 75mm lens should be ok but in fact, it is not.
I use all Fujinon lenses and have a 75mm which would almost focus but not quite. I simply took the focus carriage to pieces and cut and filed the 3D printed part that moves on the focus screw thread. Took about 5mm off it and now it focuses a treat with plenty of meat left on the part in question. Means I can use the 75mm without an expensive inset lens board.
Hi Terry thats what I found with my 75mm, like I said I made a plate that fit on the focus slider to do the same thing as you did. I am just in the process of seeing if I can design and 3d print a inset lens board to work with this lens. Also Intrepid do not make a 00 Copal lens board.
My lens must be one of the early ones as Ian described it in his above post.
Best of luck with making your own lens board, would save you the hassle of trying to find a recessed 00 board though. Probably cheaper as well.
I have a 1962 Schneider brochure that shows the 47, 65, 75 and 90 mm f/8 Super Angulons mounted in the Compur 00 shutter; a 1966 brochure shows the 47 and 65 mm f/8 Super Angulons in the Compur 00 shutter and the 75 and 90 mm Super Angulons in a Compur 0 shutter. Dates of these brochures is based on what I take to be date codes.
This is a good source for determining the production date of a Schneider lens based on its serial number: http://web.archive.org/web/20121115075344/http://www.schneiderkreuznach.com/service/serie.htm We have Dan Fromm who posts on the Large Format Photography Forum to thank for making this resource readily available.
I wonder does Intrepid make a "blank" lens board, possibly with a small pilot hole, that can be bored out to whatever size one needs?
David
Interesting, I have a 1970 (IX 70) Schneider Professional lenses review, the 47mm and 65mm f8 Super Angulon lenses were still in Compur #00.
It's odd that Deckel never improved the plain #00 Compur Rapid, but the market for their main use folding cameras had largely disappeared, and Deckel & Gauthier were making customised Compur & Prontor shutters for the German 35mm cameras that were dominating the amateur market for a while.
There have been no spare parts for the Compur #00 for some years, so it's worth looking out for a complete shutter, I have one in case anything happens to the shutter of my 65mm f8 SA.
Does this 1970 bit show any Schneider lenses available in Copal shutters? I have a gap in my literature collection. A January 1968 price list shows only Compur and Prontor shutters. A 1976 sheet on the Symmar S shows Copal also available. I did buy a 121 mm Super Angulon new in Fall 1972 that was mounted in a Copal shutter.
David
No mention of Copal shutters in the 1970 brochure, there were Compur Electric shutters. However after WWII Deckel (renamed as Prontor) and Gauthier were owned by Zeiss and merged. With the collapse of the German camera industry by the early 1970s the only Compur shutters made after 1973 were for Zeiss Hasselblad lenses, Prontor took over production in 1976.
Prontor released professional LF shutters with more control, both the Aperture and Shutter could be opened with preview levers for focussing, but they were very expensive compared to the Copals. I have a brochure somewhere and the Schneider lenses were available in either a Copal or a Prontor shutter.
Shutters were only a small part of Deckel's production, they also made machine tools, these are still made today.
I have a 65mm f/8 Super Angulon in this configuration (but as someone mentioned, it's a Compur, not a Copal) that I used with a 3x2 Speed Graphic. It's a very nice, sharp lens, but it does require the aforementioned 90 degree shutter cable adapter to be used properly.
Thank you. Based on the 121 mm Super Angulon I purchased in early 1972 along with several 90 mm Copal-mounted Angulons I've seen on ebay with serial numbers in the range 11, 086, xxx - 11, 358, xxx I'd say Schneider started offering Copal mounted lenses early in the 1970's. Incidentally the data sheet I cite above was specifically for the 210 mm Symmar-S and shows it was available in the No. 1 Compur, the electronic No. 1 Compur, the No. 1 Prontor Press, the No. 1 Copal, and in the electronic No. 5 Compur (!). No idea what offering it in that No. 5 was about.
Gauthier also made machine tools, I've seen, for example, one of their Swiss-style automatic screw machines. Unlike Deckel, this line did not continue.
Drifting off topic here. Here's some information including history on the Deckel machine tools: http://www.lathes.co.uk/deckel/index.html
Deckel milling machines of course are now all CNC. I understand there is a company on the continent that rebuilds the manual machines to as-new state. Love to have one but will remain content with my US-made Bridgeport.
David
Amazingly I have a 90mm f6.8 Angulon in a Compur with the SN 11358,5**, so made in 1969, it may be from the same batch. They aren't listed in the 1970 Schneider brochure, and there's no mention of Copal shutters. However, shutter serial numbers and lens serial numbers don't always match in terms of year of manufacture, so it's like the Copal shutter versions were fitted in a shutter slightly later.
All Schneider LF lenses (except those in #00 shutters) were available in a barrel mount, so lenses weren't all fully assembled until ordered.
Well after two test lens board's I now have a working inset lens board on my Intrepid Mk4 for my 75mm F8 Angulon lens, I managed to create a slot in the side of it so I could use the cable release with it.
I also have a Instax wide back, but when I tried to use this on it, it was again just not able to focus because of the extra spacer you use on the wide back to focus , so I put on the plate I made for the focus slider and this gives me enough backwards movement to use the instax wide back and get good focus.
Took 3.5 to print, with some slight sanding.
Very nicely done. I like how you did the slot for the cable release.
Regarding the shutter, I'm sure if the front cover, the bit that's labeled "Linhof", were taken off it would uncover the words "SYNCHRO COMPUR" engraved on the speed setting ring. May be my imagination but I think I see the bottom of some of these letters peeking out in the first photograph.
David
Hi David I tried to remove the front cover to look but it wont budge. So better left..
David
It doesn't, the casings are thicker, and it's just a thicker machined front plate, I have some of these Linhof marked shutters. When you have a crossover of shareholders between Linhof, Deckel, and Zeiss, you can get most of what you want in a shutter.
The Linhof select bit was triggered by poor quality Schneider 90mm f6.8 Angulons, my first bought around 1988 wasn't sharp, another I borrowed wasn't either, my third was great (still is). Some years ago an Australian repair technician (Razzledog) realised it wasn't the lenses, and that the shutters barrel lengths on the unsharp lenses were out of tolerance, he corrected poor shutter lens barrels to the correct tolerance and suddenly the poor lenses were sharp.
Someone made a decision to keep the 90mm f6.8 Angulon lenses in old stock Compur #0 shutters with no preview, other lenses had the newer shutter with preview, only the very late 90mm Angulons are in the newer Compur #0 with shutter preview.
I was speaking hypothetically. I've never tried to remove the front cover from a rim-set Compur shutter and yes, better left alone ;)
David
To be sure I'm understanding you Ian, you are saying that that serrated edged shutter speed setting ring that looks like the stock serrated edge Compur shutter speed setting ring is not in fact the stock Compur part. And so if that squat conical Linhof labeled front cover were (somehow) removed we would not see "SYNCHRO COMPUR" on the speed setting ring?
David
David
The stock shutter speed ring ring is the same, the part you are asking about is the Linhof alternative, no it's not quite a regular Compur.
