Which Film Holder for 10x8?
M
Moose
Guest
Hi, I am looking to get a Harman 10x8 Pinhole and need some info on film holders. I have used Fedility Elites in 5x4 size with no problems, I believe the ones branded 'elite' model are better? I have heard people say that the Toyos are the best ones you can buy. I only need one holder for now so paying a bit more isnt too much of a big deal. Is there any truth to these statements?
Thanks !
Don't know the significance of the word "Elite", but I think Fidelity is no longer in business. (Can someone confirm this?) Toyo does make a nice film holder (I have some). Linhof & Studio shows both 4 x 5 and 8 x 10 Toyo holders. I think some of the camera makers like Chamonix and Shen Hoa also make film holders.
A cursory google search turned up this from 2006: https://www.photo.net/forums/topic/171147-where-is-the-difference-astra-elite-lisco/
Among other things it mentions that back in the day Fidelity acquired another major US maker of film holders, Lisco, and continued to use both brand names. Many of my older film holders, purchased new back in the late 1960's - early 1970's, were Lisco.
David
I own, and have used Lisco, Fidelity, and Kodak sheet film holders, albeit in 3x2 and 5x4, not 10x8. I've seen no appreciable difference in performance among them assuming they are kept clean and maintained. The dark slides need to be occasionally cleaned or washed. I routinely use a source of clean, oil free air, to blow the channels and light traps clean on the holders each time they are loaded with fresh film. I also store them in static protective bags (the sort you get new electronics shipped in) while in transit/not in use.
The only things I've ever seen go bad on a holder is rust on the older metal models, cracked dark slides, and degradation of the tape hinge at the bottom of the holders.
I have three Fidelity Elite holders and one Toyo holder in 5x4. They all function perfectly well but I would say the Toyo holder is definitely of a higher build quality than the other three.
Just my opinion, of course…
I have used Fidelity and Toyo. Both work well, but the Toyos seem more solid and that’s what I use. Toyos are still in production.
I once bought an old wooden one unseen but it turned out to be warped and some of the joints gaped.
The Chamonix ones look excellent, but they are more expensive.
There seems to be little practical difference in the Fidelity holders, apart from aesthetics, (was there a difference?) but there is a version where the slide is locked in place internally and released by pressure on a white button when it’s inserted into the camera. One of my cameras doesn’t exert enough pressure to activate this.
If you were shooting with different films, using different brands for each might be an easy way to differentiate, but that sounds like a rather extravagant luxury.
Intrepid have new 10x8 Toyos. Walker have them but they are not priced.
While looking, I found this. Very interesting. Perhaps it should have its own thread.
There's been a fair bit of work done in this area. For example:
Heiland also make one for Bessler and Omega enlargers.
