My Wista 45DX came with a Wista #0 lens board which is offset. When the red dot is aligned with the correspoding red line the 150mm Sironar N lens is in the correct position, no rise or fall relative to the focus screen. Checking my other lenses my 90mm f6.8 Grandagon, and 75mm f5.5 Super Angulon are also on offset Wista lens board, my 90mm f5.6 Super Angulon is on a Toyo View board also offset.
Checking my spare Linhof/Wista lens boards, two more are Toyo View and 3 Chinese copies are offset, another Chinese board is drilled centrally. I'd forgotten another case with lenses and there's another 4 lens boards, the other is central.
It's worth noting that regardless of the hole size the offset is identical. It seems that Linhof, Wista and Toyo. etc meant the lenses to be mounted off set, and that standardises the position of the lenses. Genuine Linhof/Wista recessed boards are off set, but the relevant levers are on the sides so the off set makes no difference, actually on a late Compur it would make it harder to use the shutter preview lever.
