Advantages of Focal Plane shutters and LF cameras.
It is a good question to ask why some cameras use Focal Plane shutters, and why some cameras use both Focal Plane and Leaf shutters.
Essentially there are three reasons. First is they allow the use of high shutter speeds, back in the days when early leaf shutters were in their infancy, Thornton Pickard sold Focal plane shutters with speeds to 1/1000, there were also TP front mounted shutters with similar high speeds. The disadvantage of these early high speed shutters was they used a narrow slit in their shutter curtains, so they were for specialist use. This is the 1890s and the top speed of the best Leaf shutter, the Bausch & Lomb Unicum, was 1/100.
By the early 1900s Focal Plane shutters changed from a single curtain with one slit and tension adjustment to change speeds. Two different approaches were taken, the simplest is a much longer curtain with multiple slits of increasing width, again with a combination of tensions, an early example is the Wm Butcher Popular Pressman reflex camera, this method was used by Folmer Graflex in the US for their reflex cameras and also Speed Graphic. This allows speeds from around 1/15 to 1/1000, but the disadvantage is they aren't self capping.
The second approach is two curtains with an adjustable slit with, initially these were add-on backs for field cameras but quickly used in Reflex cameras, the most common being the various Thornton Pickard Ruby reflex cameras, almost all are self capping so when you re-cock the shutter both curtains over-lap and there's no gap, as the reach the top the first curtain locks in place and the second outer curtain then keeps moving to the set shutter speed creating the required slit width. Once tensioned you cannot change the shutter speed, in terms of decreasing the slit width. This carried over to Russian FED cameras.
So focal plane shutters are used on LF Reflex camera. But they were also used on folding Press cameras like the Goerz Anschut. The first camera to have two shutter was the Thornton Pickar Focal Plane Imperial Two-Shutter Camera, a Triple Imperial field camera with a Focal Plane shutter for higher shutter speeds, and a Between lens roller blind shutter for slower speeds and T. However speeds between 1 second to 1/10 were difficult.
When Deckel introduced the Compound shutter with a pneumatic slow speed controller in 1902 we had the first reliable leaf shutters, Bausch & Lomb began making them under licence in the US. Deckel's partner Patented a better slow gear train just after leaving the partnership, Abbe of Carl Zeiss realised this was a problem and bought the Patent. A new partnership was formed owned by Deckel, Carl Zeiss, Bausch & Lomb, and Alfred Gauthier (a competitor shutter manufacturer - Printor. Vario, etc). The Compur was released in 1912, with a top speed of 1/250 later 1/300, eventually the Compur Rapid had a speed of 1/500/
It wasn't until after WWI that cameras appeared with both leaf and focal plane shutters aimed predominantly for press use. An example is the Ihagee Zweiverschluss Duplex made in 3 sizes 6.5x9, 9x12, and 10x15, usually with a f3.5 lens. However the larger Compur shutter needed for example a 135mm f3.5 Tessar only has a top speed of 1/200, while the Focal Plane shutter allows faster speeds to 1/1000. Other companies like ICA/Zeiss made similar dual shuttered cameras.
Now the third reason Focal plane shutters are still very useful today, first you can use any barrel lenses from Petzvals to more modern barrel lenses, but there is another area overlooked, many longer focal length lenses in larger shutters like Compound/Compur and Copal #3 shutters, or larger US Betax/Alphax and similar shutters have relatively low top speeds. The Compound or Alphax #3 is 1/100, the Copal #3 1/125, larger shutters are slower still.
So for one of my projects often using a 240mm f5.6 Nikkor W, or 360mm f5.5 Tele Xenar, both #3 shutters, using them with a Speed Graphic and its Focal Plane shutter gives me faster speed options that I need to stop movement.
Focal plane shutters are fine as is the one in my 9x12cm Mentor Reflex camera (still being a slow shutter):
On the other hand depending on the onedirectional movements of curtains there exist phenomena you never will see with leaf shutters:
I have a Mentor, the screw holding the Speed dial in place has been sheared off, so it's going to need precision to remove what's left. You don't happen to know whether it's a reverse thread.
The Lartigue image is of course well known, it's obviously a camera with a single shutter curtain, a smallish slot at low tension, he must have been rather close in this particular shot.
