Recessed lend board.
Hendo'svan
Does anyone have expierence with using a recessed lens board with a 90mm Super Angulon f8 on a Wista 45 DX, mine is on a flat board and today I was struggling to use any movements as the lens is right up against the bellows. The bellows are brand new as I only fitted them last week, so they are maybe still a bit stiff, but I don't want to put them under any stress.
Thanks in advance for any reply's
Andrew
I've been using a Wista 45DX for years, since around 1986, I've never had an issue with my 90mm f6.8 Grandagon on a flat board, and no problems with a 75mm f5.6 Super Angulon either.
I think it's the new bellows that are at fault, not up to the originals standards.
I have a Wisner Technical Field which is spiritually similar to your Wista. It has a lot longer maximum bellows draw, hence more bellows to contend with. So, I bought the recommended bag bellows for use with a 72mm f/5.6 Schneider Super-Angulon XL. Quite by accident, I discovered that if I racked the normal bellows all the way back, tilted the front standard back, and the realigned the lens with lensboard front tilt, I could get away without using the bag bellows in many cases. I don't recall if this can be done with the Wista as it requires independent control of the front tilt and lens plane adjustment, but it's perhaps something to look into.
It isn’t so much the stiffness of the bellows; it’s the accumulated thickness. That’s been my experience. The Chinese kindly make lens boards at reasonable prices, so why not have a go anyway? There are different depths available.
It might not be significant for your setup, but a recessed board makes it more difficult to operate the shutter and aperture. On some shutters, the f-numbers are almost invisible. It might be useful to have an angled extension for your cable release, too.
As far as I know, your Wista has fixed bellows so the solution of bag bellows is unavailable.
Talking bellows. Could the camera front and rear standard be modified to make the bellows pop in/out as they do on my Chroma. Put a steel frame into both ends of the bellows and sink some small strong magnets into the wood, you could then swap to bag bellows in seconds?
Thanks for all the reply's and suggestions, I'm going to buy a recessed lens board on eBay for around 21 pounds, it's 12mm recessed so I hope I will be able to adjust shutter and aperture, maybe with a pen or something, I may have to try and find a cable release adapter, don't think I have seen one though.
I've found it useful to put a spot on the lensboard itself to mark my most popular aperture - f22. See how you get on before you splash out on an adaptor.
You can find 45 degree cable release adapters for sale on eBay from time to time under the Hasselblad brand.
