Light leaks (in a 6x9 Kodak folding camera)
AnalogueWendy
I'm sneaking this in, hoping that 3 6x9 cm images can quietly sidle in for some LF know how.
This is a little Six-20 KODAK Mod C that followed me home from a local charity shop. It was all about the looks; clean, pretty and working well with an interesting lens . . . but light leaks.
The camera won't get much use from me as I can't use the view finders easily, but it IS very portable. I'm expecting to hand it on to someone with younger eyes.
HP5 120 in a brief burst of winter sunshine with a very strange light leak. ALL light leaks look strange, I know, but this one is showing a doubling effect as well. I'd blame my hand-held technique except parts of the shots are very sharp ( no extra work at all on these scans).
Happy to have this ignored, or deleted by mods if it does not qualify, but just in case anyone can help me track down this leak. Bellows are in good shape and this does not look like a bellows leak to me. Not much space in there to put a light inside either.
ps Also my first film developed in PyroCat-HD. I love it already and may need to up my agitation a bit for more contrast, or even add some time.
If you don't think the bellows are the problem I'd guess the film door to be the next most likely.
Try a roll with black electrical tape round the door seals to diagnose the issue :)
Might be imperfectly closing shutter blades or some bright point inside that has lost its blacking.
Does the back of the camera have a little sliding door with a red filter behind it?
These were originally used to peer onto the film backing to determine what shot number you were on. The sliding door was intended to prevent light in from the back by default, red filter notwithstanding. Given the consistency of the position of the streaks, this might be the culprit. As @Petrochemist mentions, covering this up with black electrical tape can implicate or exhonorate this viewing port as the problem.
I doubt it has anything to do with the red window, my Gaoersi 617 camera gas a long clear window when opened and I never get any issues with Ilford or Foma films. I'd suspect a tiny leak in the bellows it may not be a pinhole, it could be a crack, the inner linings aren't usually light -proof.
Some years ago I borrowed an MPP MicroPress to assess how much of the camera was made by Graflex, just before returning it the owner said could I find the light leak. I checked with a torch in the darkroom and there was nothing, I was puzzled, instead I put a small flash unit inside the camera, with a film holder in the back and the front standard taped up there was a faint line when the flash went off. It turned out to be where the bellows attached to the body on the top edge.
Given the position and the shape try looking at the side folds of the bellows, I think it'll be hard to spot, there's a slight indication that the line extends during the start of winding on. Maybe from the front on the right hand side . . . . .
To me different things went wrong.
The dense in the corner nearby the "flash" is higher while looking like a rectangle geometric:
Then in both images there are rounded signs of a "woosh!!" left from the "flash":
At least I am wondering if the "shadow line" within the trees should be there?
This is all really useful. Thank you so much everyone. I shall investigate more and report back.
If this thread turns into a 'light leaks I have known' library, so much the better.
@Ian Grant I shall check the bellows folds and the attachment to the front 'standard'.
@Reginald S. I can see that change of density on all those shots now you have pointed it out. I was calling it 'fog' but your description is far more helpful.
@thronobulax Red window was my first thought, as it's in the perfect location but, after some messing around with film rolls, I'm not sure this much light could find its way through Ilford 120 backing paper.
@David M Shutter blades is a depressing thought . . .
@Petrochemist I have dug out a big roll of black electrical tape :)
It shouldn't. Useful observation - thank you.
This one is a disappointment - was hand-held while perched on a folding bench at the back end of a boat moored in a strong current! I was so pleased to get the shot. One of those days when someone should have been photographing me :D.
I have found it!
Took a while and a lot of fiddling around with a small, high intensity bike light. In the end it was luck because the light toppled into the bottom of the bellows.
There seems to be a fault in the shutter.Light is finding its way in/out behind the silver button on top of the shutter that controls the timer.
May respond to a traditional black electrical tape fix - no idea whether I will be able to do more than that.
Thank you everyone for the encouragement to keep looking :).
That's the self-timer, often a cause of jamming with those early rimset Compur shutters. An odd place for a light leak.
. . . An odd place for a light leak.
Yup. I think so too, but that's where I saw the glimmer of light.
It sort of matches with the concentric patterns in the images too.
I'm wondering whether it's a fault that showed up early on, as the camera has not been used very much. Someone's pretty camera stopped working. They must have been disappointed :(.
At the recommendation of someone here (@Ian Grant ???) I purchased some McNett Black Witch (for which I paid a princely sum because it had to be vended from the UK to the US) for these kinds of problems. You likely can find it more easily than I did.
The problem with electrical tape is that it inflicts sticky adhesive on what it touches and that can become problem with time. If you do use it, make sure to cut it, not tear or pull it. If you pull electrical tape, it will "rebound" its shape over time and can pull away from where it was applied.
Not me, I've never heard of McNett Black Witch.
I've just looked at a Compur Rapid shutter, there's no way light could leak through that bit and reach the film, the internals of the shutter and then aperture blades and casing make it impossible. All early rimset Compur and Compur Rapid shutters with the self timer don't fully seal against the casing, Remember the casings have slots for the release arms, aperture control, cocking lever and none of these cause fogging
The images show a far stronger light leak which must be direct, so it has to be the bellows.
.. that's where I saw the glimmer of light...
Following Ian's observations you just seem to have have an early but illuminated self-timer:cool:
Next i would check the shutterblades.
What's about making a film test with an open shutter:
You could work in totally darkness, making two test images using a flash or switching bulbs on/off, followed by test images with light and working shutter blades - maybe at different exposure times?
