Yes, it would be interesting to know how this film was exposed and developed.
In general, mid tone local- or "micro" contrast is what makes an image pop. There are several ways to achieve this:
- Reduce nominal ASA when computing the exposure and then increase development time. This is called "expanded" development or "plus" development in Zone System parlance. The more you develop, the more you have to lower the ASA (within reason). This works really well to expand the middle tones and hold shadow detail but risks blowing out the bright highlights because you can develop them to the point where highlights no longer hold any detail. This can be managed with compensating developers like Pyrocat-HD or D-23, or use a so-called "split" development bath.
- Use a very dilute developer and leave the film in the developer for a very long time, agitating only a few times. This typically gives you full shadow detail, expanded mid tones, and controls highlights so they don't blow out. The downside of this technique is that development takes a long time - 60 minutes is not uncommon - and it's very fiddly to get right. Since you are agitating only very infrequently, it's common to see streaking and other nasties on the negative if you don't suspend the film perfectly or use a special container for this. This is called Semistand (2 agitations) or Extreme Minimal Agitation (3 or more agitations). Not recommended until you have a good grasp of ordinary development methods. (It DOES work and I use it all the time, but it's a steep learning curve in the beginning.)
Either of these will produce negatives that can either be split printed on VC silver paper or have their scans fiddled with curve manipulation. Either way you can get great results with patience and practice.
Relevant references of interest:
P.S. Zone System tells us to expose for the shadows and develop for the highlights. I'd suggest that you have to expose for the shadows, develop for the desired midtone contrast, and use some means to rein in the highlights (if necessary).
