Any 3D printed lensboard users?
Peter B
I'm toying with the idea of buying one of these tophat boards for my Ebony RSW45, but have no experience of how good or bad a 3D printed lensboard might be. I'd be grateful for any info, experience or thoughts on this.
Thanks, Peter
I have my 240mm fitted to a 3D printed 40mm top hat for my Chroma, works a treat
Most 3d printers don't go up to the size needed for my lens boards (158mm square). I have made my own boards using 2mm thick sheets of ABS or aluminium. Typically with ply behind for strength.
That one is certainly a lot bigger than the Linhof size board that I need for mine.
It's still not the biggest I've seen, but yes quite a bit bigger than most.
Any smaller & I'd not have been able to mount my 150mm/1.2 on it, even at it's large size there are two holes for the flange that couldn't be used, fortunately the remaining 4 seem to mount it firmly enough.
My printer will print bigger than 158mm square, build volume is 250 x 210 x 210 mm
Presumably, it would be possible to 3-D print a top hat lens-board with swings and tilts incorporated, to relocate them at the proper optical point.
Just a quick update to say that I eventually ordered one of the lensboards linked in the opening post, and it's a good tight fit with no light leakage. It seems robust enough as well, and it came fairly quickly from Italy and without any import drama.
The Linhof/Wista style metal lens boards were quite cheap until recently, I could by them new for around £12-£15. I have 5 spares in my box of lens boards (they do get used to test lenses). I've picked all these up at camera fairs for uder £10 each.
Like others I do make my own lens boards as well, I've used Aluminium sheet to make lens boards for my Wista 45DX, the first has been in use with my 65mm Super Angulon for around 35 years, it has Compur #00 shutter. I also make quite a few wod lens boards, and conversion boards, in fact I made five lens boaards over the weekend for my !0x8 Agfa Anscos.
Yesterday I isassembled an Agfa Ansco lens board approx 7½"x7½" that had been badly repaired many years ago. I had to use boiling water to soften the glues ued, then take it apart. It is now re-glued and ready for refinishing.
For lenses of moderate weight, it should be fairly straightforward to make lensboards out of thick card, like mounting board. Any ridges or furrows can be made by laminating individual pieces. Much the same method can be used for thin MDF or ply. Obviously not as long-lasting as metal, but better than a long wait for delivery. Many economically-priced cameras seem to have had bellows made from sturdy paper, so this isn’t without precedent.
When I want to test small barrel lenses I sometimes glue pieces of cardboard or foam board together similar to plywood. Foam board is easy to cut and is great when you don’t have a lens flange because the lens thread bites into it nicely.
You can get all-black (both surface and foam) foam board too, which is very handy.
Otherwise try something like Foamex.
