Wista 45dx bolts stuck fast
It's fixed!
I am so so relieved.
I ordered the small strap wrench - and silicone spray - due to arrive later today.
I read and went through everyones solutions.
Ian I tried to tighten and loosen etc .
At home I found a good out thick rubber band - and wrapped it around - and yes - it worked.
Now this camera can be used.
Thanks so so much for all your useful advice, and also support.
Best wishes
Carolyn
ps picture of the rubber band!
Reginald S suggested adding thin washers, if there are none. It’s good advice, but not at all urgent.
Yes great advice! Will be doing this
My field camera has washers and adding them to yours is a good idea. However, I'd suggest using nylon washers, not metal. Nylon is both weatherproof and will not compound the metal-on-metal binding issues you've already experienced. I don't know about the UK, but here in the US a large assortment of small nylon washers in the usual metric sizes is available for minor expenditures. For example:
