6x9 Ground Glass Mask
Richard Lee
Could somebody please shed some light on how to mask the ground glass on my 4x5 Speed Graphic for use with my 'new' 6x9 Horseman back?
Are format masks commercially available or is it a case of cobbling something together from cardboard, acetate or similar? Thanks.
Richard
It should be relatively simple to remove the ground-glass frame, with the 6x9 back in place and lightly mark the frame with a pencil. Either the corners or a full rectangle will work. Many focus screens are already marked for multiple formats.
I hope you find something that suits your way of working.
Simply sticked to the GG cardboard is good practice, marking with pencil is good practice.
What will work best to you.
Personally I love the advantage to first see the whole scene on the 4x5" GG, determining the 6x9 frame then.
Btw the 6x9cm horseman back should be fine - mine is.
It seems a Linhof GG screen would be the perfect solution with it's apparently 'crisp etching and markings filled-in with black paint'. Unfortunately funds won't stretch that far:
I have since attempted to fashion a mask from thin card which I intended positioning forward of the GG screen (i.e., lens side). Unfortunately this proved difficult to see behind the screen but worse still, it made closing the Graflok slide clips(?) impossible. :(
I reckon the mask needs to sit in the recess to the rear of the glass and would ideally be made from something more durable than card.
Richard
Many years go(1977) I made a GG screen for my De Vere monorail, I added a 1cm grid and also the markings for 6x7 & 6x9 roll film holders, I used blue and red china-graph pencils which I carefully sharpened The lines were still on the screen when I sold the camera 5 or 6 years ago. Others use a pencil.
You might care to use thin plastic, which is easy to cut and available from model-making shops.
Most focus screens are held in place by spring clips and if you cut the mask to fit, you can give it “ears” which slide under the clips.
This would be on the “eye” side, never the lens side.
Putting anything at all inside the camera risks its coming loose and ruining your once-in-a-lifetime shot of Lord Lucan riding Red Rum down the slopes of an erupting Mount Fuji, in front of an eclipse of the Sun.
Here’s a reference to an excellent source in London, but there may be other places that are more convenient for you.
I haver a better solution, when I had a Laser printer and first began making and selling GG screens 16 or 17 yearsago I used to supply an acetate printed grid with the 6x7 & 6x9 markings as well as a grid. I still have some Richard can have one of these if he'd like.
I eventually came up with the idea of having a piece of 3mm acrylic laser cut to size. An effective and inexpensive solution, me thinks.
Anyway, many thanks to all those that contributed to the post. ;)
Richard
I very fine have pencil lines on my GG and occasionally a paper mask.
Nex time I shall use a fine permanent marker - easier to remove if/when needed.
