I need to find my thread gauge. There are two identical flanges inside diameter approx 48mm, actually 1.93", there is a third but as it's marked T.T. & H it's worth far more, while the internal diameter is again 1.93" it is actually a 2" flange. according to the T.T. & H catalogues. Ross catalogues don't list the flange sizes unfortunately.
It appears the RPS proposed standardised threads in the late 1880s, which some manufacturers like T.T. & H Cooke adopted and, in 1890 also Ross Ross, 24tpi for smaller lenses and 12tpi for lens flanges 3" and larger.
Having found my thread gauge the first two flanges are slightly finer threads, however I found two other brass flanges that are 24tpi, the better one is 1.96 " internal diameter essentially it's the same as the T.T. & H flange, the ridges on the threads are not as sharp.
You need to get better information somehow, there's one for sale claiming the 6" Xpress takes a 47.5mm x1 flange, but Ross never used metric sizes. Part of the issue is when you measure the internal diameter of a flange that is misleading, so the Internal diameter of a Leica M39 enlarger flange is 37.9mm, a IIIa camera 37.5mm, the thread on the Summar lens 38.96, and a Gnome (Japanese) enlarger lens 38.60
Measuring my Ross Combinable lens flange, it is apparent it's nominally an 1 5/8" flange, so yours may be 1 7/8", rather than 2".
