A Warning when buying 7x5 (5x7) DDS Film Holders
At least 2 UK sellers on eBay have listed Half Plate 6½" x 4¾" DDS often also marked as 12x16.5 cm, as 7x5 (5x7). These holder will not take 7x5 film only Half plate.
Modern Half plate, European 13x18cm and US 7x5 (5x7) DDS Film holders all have the same outside dimensions, so all fit International backs (for the formats). However they can only be used with the marked film sizes.
So . . . I remembered seeing this post about 24 hours after pressing the ‘buy’ button. Very confusing and I shall now request a return to the seller.
I’m wearing out my beautiful wooden book-form plate holders and beginning to think again about fitting a new, more reliable back to the camera. Ah well, back to the drawing board:rolleyes:.
It's worth adding that there is a similar issue with modern 9x12 and 18x24 holders. Last year I bought a lot of 5x4 film holders (30+)at a Camera Fair, he said he had more in his car. He added in 4 9x12 holders, thinking he could hoodwink me. what he didn't realise is I do use modern 9x12 holders, and wanted more :D
One problem is the actual size is printed with white ink and is on the area we use to pull holders out. so can get worn off.
With 4x5" and 9x12cm the difference is clearly visible, but probably not on ebay pics.
With 5x7" and 13x18cm it is a bit of goodluck - some films will fit, some not.
Once it took me nearly 15 minutes to understand the phenomenon not seeing the subject through my camera inspite of opening wide the aperture - the film from the last exposure has flipped off the holder and then lurked in the bellows :)
. . . not seeing the subject through my camera inspite of opening wide the aperture - the film from the last exposure has flipped off the holder and then lurked in the bellows :)
Good to hear that these things happen to other people, not just to me :D I've had film flip out too.
7x5 sheet film will fit 13x18 holders but depending on tolerances may fall out in use. Sheet film sizes are nominal. slightly smaller than the glass plate and similar paper sizes, this is because originally sheet film was used in cut film sheaths, in book form plate holders.
When Ilford began test production of Harman Direct Positive paper they the test samples they sent out wouldn't fit most DDS film holders, they'd cut the paper to their usual paper dimensions, and not the slightly smaller film dimensions.
I almost got caught out by the 5x7 versus half frame film holder conflict. I ordered two 5x7 holders from a famous British second hand retailer, only to find than one was 5x7, the other half frame. I sent the half frame holder back and it was replaced. Without close examination I suspect it is difficult to differentiate between the two sizes especially until you try to load the film.
I have some wooden Kodak half plate film holders but it would be easy to spot the difference compared to Fidelity or similar 7x5 plastic holders.
The issue is where outer appearances are identical.
This is a comparison of a Sinar (Lisco) 9x12 holder and a Fidelity 5x4.
Note the moulded plastic says 4x5 and then below the Sinar brand the 9x12 cm which easily wears off. It's the same with plastic Half plate film holders.
I found you had to get these from the US to be reasonably sure it is full fat 5x7. Bought a few off Catlabs and US ebay that were OK.
Half plate films disappeared of the shelves here in the UK around 1977/8 along with whole plate, although Kodak Ltd still supplied Ektachome in these sizes to the large catalogue companies like Kays, Moores, etc as every image was shot to the exact size it was printed on a page. This was why they were printed10x8 format. Kays in Worcester had 6 or 7 studios, and usually two set-ups in what were quite large studios,, something like 14 photographers, then assistants, plus their own in house E6 processing.
So there were no new 7x5 DDS film holders sold in the UK until around the 1990s when people stated importing 7x5 camera from abroad. as a consequence they are hard to find secondhand, particularly at a reasonable price. I bought mine from the US, high International postage costs are making this less economic.
