Help in Identifying Plate / Film Size
the void
Hello everyone, are there any good resources for identifying what size of film holder I need for my camera?
I've recently came into possession of a W. Watson & Sons camera, appears to be the "Premier" model, it is in a relatively great shape for its age and appears to be fully functional. It did not however come with a film or a plate holder and I have a difficult time identifying what I need to shoot with it. The closest I'm familiar with would be 5x7 inch film but this seems closer to a plate setup perhaps. Any chance I can shoot 5x7 film with this and if so what holder do I need?
Second question, are there any resources for identifying age of this camera by serial number? I could not find anything via google search.
Please help me if you can, I would love to take it to the field and test it out.
Thank you!
Camera looks lovely! Do you have a Watson lens too? Looks like you might have the tripod there which is a big plus.
I'm currently in the middle of building an adaptor to use international 5x7 film holders in an older whole-plate camera. It's a very fiddly project.
You may need something similar.
My first suggestion would be to buy a 5x7 film holder (Fidelity, Toyo, whatever they are all a standard size) A second hand or tatty one will be fine. It does not even need to work at this stage.
Then start to look carefully at what kind of a rig you are going to need to fit holders like the one you have bought into your camera back. I'd expect some woodwork or perhaps 3D printing to be needed.
Another option might be to buy a whole new back that will hold standard film holders and then make the back fit onto your camera.
I'm happy to be wrong about this and have someone tell us that Watson 5x7 holders are either standard, or easy to find . . . or something. The cameras seem to have been made for a very long time so that could be the case.
Cameras like that don't usually have serial numbers, and in later years the Watson cameras were made by Gandolfi. This one is an early discontinued plate format 7½"x5", sold for £10 in 1916 (and earlier). A complete outfit, lens darkslides etc was £22 9/6. It's not a format I'd noticed before, rather like the British made ICA Tudor I bought a few weeks ag which has an 8x105cm back, luckily a quarter plate back is interchangeable.
If I get a chance I'll copy the 1916 BJPA advert showing this format, and the others. A quick glance an Kodak Wratten don't list the plate size, nor do any others Illingworth, Gevaert, etc. I would guess the format disappeared by the end of WW1.
The Premier design comes from Perken & Co, Louis Gandolfi worked for them, Watson had links as well. Almost identical cameras were made by Perken, Gandolfi, Watson, etc,all using t brass fittings from the same foundry. So you can see this camera and the Watson Acme field camera with a variety of names, with only occasion slight differences.
Yes Wendy indeed it came with a tripod, not a Watson lens though it has a "Compur Wallace Heaton Ltd Sheffield and London Zodellar Anastigmat 4.5 no 4" on that mostly works still but has timing issues with the shutter release as expected.
I think you are correct that some woodwork or 3D printing will be necessary as I could not match it to any modern standard even looking at this extensive chart on Wikipedia http://camera-wiki.org/wiki/Plate_sizes
I do have a wooden standard 5x7 film holder which is a tiny bit too small, and obviously does not have the notch for locking in, but could work as a template for this "mod". With that said I want to keep this as close to original as possible so getting a different back would be a last resort.
Thanks for you input!
Thanks Ian, this one has some sort of a number (maybe serial) on the back side. And some patent numbers on the tripod mount.
Thanks for the historical context not that much on the internet that I could find besides basic info.
OK, many wooden parts of British cameras are stamped with a number, in the case of your camera the Premier was made in 6 sizes, as was the Acme field camera, and they shared no common parts. So parts were numbered, for instance the assembled base board, the lens board frame, different parts of the back etc.
A search of a BJP Almanac solves the mystery of the 7½"x5" format, it's actually also listed as the Continental European 13x18cm format. So Thornton Pickard sell some cameras as 7½"x5"/13x18cm, and others are available as 13x18cm and 7"x5". These would be for export.
Film sheets of 13x18 cm are nearly the same size as 5x7". Nearly - both could fit to the wrong type of filmholder but often does not.
7,5" has 19cm, 5" has 12,7cm.
For this old cameras wooden filmholders are required which often came as double film holders in the socalled book style, concerning the opening patent.
Since most ancient camera producers have had their own filmholder type which often don't fit to other cameras it is hard to find the right one.
Adding a modern back using modern filmholders in this case is always a good idea, especially for giving comfortably usage.
For example this eastgerman Pentacon Globica 13x18cm works fine today with an international 5x7"/13x18 back from Plaubel instead of it's wooden filmholders.
The same back fits to my meanwhile fine working russian 13x18cm Reisekamera:
Both cameras are able to take a Plaubel 4x5" international back which is a simple thing of homemade adapters (wooden plates holding the 4x5" back).
In spite of being 30x40cm this is the type of filmholders which you are looking for - for staying completely original.:
I recommend finding an international 5x7" filmholder which outer dimensions will fit to the inner dimensions of your camera.
In my case no sawing or otherway mistreating my cameras has been necessary.
Thank you this is useful info, I will experiment.
