A new 'temporary' addition - Voigtlander Bergheil
moggi1964
Picked this up at auction today as it comes with a well rated lens - Heliar 15cm F/4.5
Does anyone know much about them?
I bought it partly out of curiosity and partly to hopefully try to make a few pounds selling it on.
Like Dagor and Protar lenses it's the longer focal length Heliar lenses that are sought after. 9x12 film is readily available you just need some plate holders and film inserts to test it.
I think I have a few of the flat edge 9x12 plate holders.
Thanks Ian. I'll see what turns up and update the thread.
Before selling a Heliar I would give it a try.
Ian is right with Heliars and focal length but since yours is a true Heliar you may explore and discover some wonderful things.
I never tried out my 150mm Heliar but regulary use my 360mm Heliar with the 12x16" camera.
It's my preferred lens for near distance shot wide open, which gives a sensationel rendering while delivering smoothness and sharpness.
Except in ancient pics I never have seen before such kindly deep shadows:)
Thank you for sharing your thoughts, it's appreciated.
looking forward to getting it and testing it.
There are a few cult (general purpose) lenses, Dagor, Heliar, Protar, are the main three. All are better for B&W work rather than colour.
How good are they, my 12" C.P. Goerz Am Opt Dagor came with a 10x8 Agfa Commercial View, the seller (a Professor of Photography) said it was useless. He had never used it, he used the 10x8 camera with a 300mm f9 Nikkor M to copy artwork, I guess he wanted the flash sync.
So after my camera arrived with it's 12" Dagor I tried it, the lens is coated, the original owner had it factory coated after WWII, why on earth the second owner had not even tried it is beyond me, it's a superb lens.
It is and I know I've only seen a bit of it. ;)
I was like a grateful kid in a sweet shop.
At the moment it's like Stanley Kalms, of Dixons, pile them up high, at least with the SLRs, oh and maybe the wood & brass filed cameras. Then there's the 35mm SLRs, and the LTM mount cameras (all for sale).
She's here and looks fab. Shutter works, GG looks decent and it lacks film/glass holders so I will be in touch, Ian.
I'll dig out my box of plate holders, just have a look at the edge fit of the GG screen holder, or post a photo showing the edges, and also the back of the camera with the screen etc removed. I might have a Rollex 6x9 back as well.
That's the first time I've seen a DOF table on a 9x12 camera. The lens serial number shows it dates from 1928/9 so one of the last Dialset Compur shutters (of its size).
Your camera comes with interchangeable bajonett lensboard mounting.
Just shift the lever sitting between shutter and standard to the left, or right for loosen the lens.
All you now need are - lensboards with lenses:)
Do these help, Ian?
Looks like the holder need a lip, best to try some, you already know how many I have :D
I'll be in touch, Ian.
There is also another serial number on the side of the shutter mechanism.
Since to me these old, sometimes rusty and sealfelt missing holders didn't develop great usage I preferred installing a Plaubel 9x12cm back to my wonderful 9x12 camera, taking these sensationel, easy to load and luckily near mint Plaubel/Linhof 9x12cm filmholders .
Could also be done with an original and flat 4x5" back if size of the camera isn' of any interest.
Tha
The shutter serial number is much older 1920 but that's not uncommon. There were so many variations of the Dial-set Compur shutter which were made in batches, so less common variants might sit on shelves for sometime before use.
@Ian Grant if I send the camera down to you can you pair up some film and if you have them plate holders and send it back?
