If you are a little but handy with tools, you can make an extension for the back. The top-had idea is excellent and you can simply order it and begin your projecr as soon as the postman has gone.
But there are two disadvantages to the top hat.
Firstly, if you use movements to any extent, there may be cut-off from the tube as it intrrupts the rays from lens to corner of film.
Secondly, a lens in a top hat is quite bulky. You may be able to get tolerate this, or you might, for instance, tuck your darl-cloth inside, just as one tucks socks into shoes when packing for a holiday.
A rear extension is just a box, open at both ends that fits between the body of the camera and the frame that holds the ground-glass assembly. Obviously it can be made to any convenient length, certainly longer than the top hat and it works for all your lenses, so useful for macro work too.
I say "just a box", and so it is, but you will then need to duplicate the fittings to hold it in place. That might be tricker, although a rough and ready job might be done with gaffer tape.
