Letcombe Brook
You've tamed the Foma contrast nicely :D
It's worth trying a green filter when there's a lot of foliage, it really helps with the details.
I've never really had a problem with the contrast on Foma film using Ilfotec HC, a developer I use for most films and situations unless there is a very good reason to use something else.
As it happened I did also take one with a green filter, from a different direction (down to the left of the original).
Same development and lens, 1/4s, f/11.
To me it doesn't work as well, but that is probably more about the composition of the shot than the filter choice (should have been more to the right and a longer lens—I did have the 150 with me).
Reactions: Diz
Good to see you are making use of the camera James and thanks again for the purchase.
