Just bought a new camera.
soupdragon
I am now the proud owner of a Tachihara Field Stand 8x10 in Cherrywood.
I'm hoping my Schneider APO 240 5.6 has enough coverage for 8x10 format.
I was going to ask if this was a good camera or not but I guess at the end of the day it is just a spacer between the lens and the film.
It does not appear to have a lot, if any, swing or shift. That said, given I mainly use tilt, I'm hoping we will become friends.
Have I lost my mind?
Looks fantastic! I reckon to do LF we all have lost our minds!
I saw it at Ffordes. Looks great and should be very capable. Check the bellows well for light leaks, just to be on the safe side.
Your 240mm lens has an image circle of 352mm @f22 @inf. while 8x10" film has a diagonal of 312.5mm, so more than enough for a little bit of tilt for landscapes.
Have fun!
And it seems to have some front standard swing, probably enough for most situations.
I am so excited. I feel like a child at Christmas Eve.
Sadly I still have no ideaa as to the best way of processing 8x10 slide film at home.
Have fun!
I'm paying more than I want to but they did throw in a lens board to match my Schneider 240.
I guess I can get something back if we fall out.
Does it takes Sinar/Horseman lens boards approx. 140x140mm dimensions?
If so, it might be worth getting a lens board adapter at some point, if you wish to swap and change between formats and systems more comfortably.
Ffordes are a decent outfit in my experience.
Here's the instruction manual.
Especially helpful for the correct operation of folding the camera and avoiding unnecessary (bellows) damage.
  • TachiharaManual.pdf
It might be worth your while to get some B+W film for a bit of practice with the new format. 10x8 is a whole new world.
Paying more than you want is a very common problem for everyone just now and not only in photography.
My heart is set on seeing a 8X10 positive.
Having invested more than I wanted to in big format, I'd be robbing myself if I didn't try.
I can, however, see where you are coming from regards cost, It all seems to go up exponentially with format.
