- Dec 19, 2017
I went out today to the same spot and it was miles easier to focus due to ever so slightly more open shadows.
I took three shots then went to check out some FUJINON lenses. I tried the 105mm, 125mm and 135mm. No fall off whatsoever so ever when going wider.
I picked up the 135mm 5.6. Back home the 135mm has a much bigger spread of the brightness compared to my 150mm. Weird.
Today shows I need to shoot and practice more.
Appreciate the input
It is about familiarity, also confidence. We have to realise that most LF lenses are relatively slow, f4.5, f5.6, f6.8. f8, and I do have f12.5, f14, f16 lenses. When you add an f3 8"or f3.5 6" lens (I have both) you realise we are using slow lenses for LF., and they are more difficult to focus.
I do wonder, I have early Ross f14 EWA lenses for British Field cameras, and some other f16 WA lenses,he original screens were coarse and 2 stops dimmer, maybe we are impatient, just how long would you hide under a dark-cloth until your eyes acclimatised.
