- Aug 22, 2021
Has anyone come across one of these lenses before? The engraving on the side reads: Adams & Co. Augmentagraph lens. From the markings on the side it covers up to 20x16.
I can find next to nothing in terms of info online except for this:
The 12x10 camera I bought last month came from a museum and inside the camera case was a label (I assume the label was displayed with the camera at the museum) which mentioned this Augmentagraph lens but only the flange came with the camera. This is the same flange I asked for help identifying in an older forum post, it has an R engraved on it. By sheer luck, I stumbled across this lens a week ago on the well known auction site and I was the winning bidder. This lens came from the same seller as the camera so I'm certain they were both together at the museum.
What I'm trying to work out is what the aperture numbers relate to in today's measurements. I can't believe this is an f5 lens and that's the lowest number on the scale. I mounted this lens on my 12x10 camera with a subject around 10 feet away and the bellows extension was approx 22 inches which matches the markings on the side. The black rear section can be removed but the strange part is there's a fixed piece of black metal inside, between the middle and rear lens groups and the hole in the middle is much smaller than with the aperture blades fully open which probably makes this lens at least 2 stops slower.
Removing the black rear section doesn't work because the remaining thread doesn't match the thread on the flange so the rear group is clearly needed. If anyone has come across one of these lenses before I'm keen to learn more about it.
Catalogue Page from Exhibition Catalogue: 1895 Fortieth Annual Exhibition of the Royal Photographic Society
showing (E95A021) Exhibit no. 476: Augmentagraph Lens by Adams & Co. ()
