210mm compared to 240mm
Soulstar89
Hi folks,
Hope everyone is well. Im deciding on whether to go for the nikkor w 210mm f5.6 or find a rodenstock apo ronar 240mm f9. The purpose of the lens will be portraits. With natural light and strobes on my Wista 45vx
The rodenstock is on a copal 1 shutter so is smaller than the copal 3 which 240mm is normally on. I lose out on image circle but have a more compact lens.
What i cant find is how the compression of the same framing, say head and shoulders or just below the breast will be. You will have to move further forward to achieve the same framing compared to the 240mm. I understand that distance is the factor on perspective and compression.
Another factor i found is the nikkor is a plasmat design whereas the Rodenstock apo ronar is a Dialyte lens design.
Gone are the days i could go to a store and see for myself so I have to ask these questions.
Help would be much appreciated.
Aaron
I have a 240mm Nikkor W, it is quite a large lens in a Copal #3 shutter, however it also covers 10x8. I also have a 210mm Symmar S.
The downside of a 240mm lens on a 5x4 camera is when you start using it for closer distances when your camera only has front focussing. In these situations, rear focussing is much easier. I'd start with a 210mmit's a more useful focal length, if possible, unless dirt cheap I'd avoid f9 lenses.
This is why forums like these are invaluable. I didn’t realise the downside on focusing. Yes my wista only focuses view the bellows. So lenses like the nikkor 300mm m which is a tessar design would be even more limiting?
I have a nikor W360mm, on my Rittreck and close up I need to use the rear movement to get focus, big heavy lens but pin sharp.
I have a 210mm f/6.8 Caltar-II which is a rebadged Rodenstock. I have many other choices, but this it is the most used lens on my 5x4 Wisner field camera - by a lot. It's a great angle of view and a very small, not to mention, very sharp, lens.
Having said that, I do almost no portraiture and none at all with 5x4 so I cannot comment on your particular situation.
Thanks for input on my rz67 I use my 110mm for 3/4 length and my 180mm for any things waist up. If I wanted a similar feel as the 18m on my rZ67 I would have to go 300mm +. I don’t think that is practical with my wista so I will settle for the 210 and see how I get on.
There was a quite current thread on 300mm lenses on Photrio recently.
I have one of my 10x8 Agfa Ansco cameras set up (on a tripod) all the time and a few 300mm lenses. The lenses range from an f9 Nikkor M, a 12" f6.8 Dagor, and my recently purchased f4.5 Xenar. these are the lenses in shutters, then I have 2 Wray lenses a 12" f8 RR, and a 12" f6,3 Lustrar (coated).
When you stick them on the same camera, it's an eye-opener. The faster the lens the more precisely you can focus, and very quickly
The Rodenstock 210mm f6.8 was the Geronar, a budget multi-coated Cooke triplet, I thought it was sold as a Caltar-E in the US by Calumet. It is a very small light weight lens, very sharp sopped down, but a typical Cooke portrait design wider open. I have a 150mm & 210mm Geronar.
Cheers for explaining this.
I did see the 300 lens thread. I’ll have another read through.
What are the characteristics of a Cooke triplet design in the wider open apertures? I really like the 180mm lens on my rz67 as it’s a tessar design. Sometimes I can see pours and baby hairs of the talent with my FUJINON 135mm. It surprises me how mich resolution and sharpness you can get. Sometimes i want to soften it up a tad.
I agree with Ian about the 210/5.6 being a good choice for portraits on a Wista. You'll enjoy the brighter image to focus with compared to a 300/9 and the ability to focus closer without struggling with maximum bellows extension. The Nikon 210/5.6 I've got covers 10x8 but feels like a very wide-angle lens on that format and not really to my taste. I've got a Fujinon 250/6.7 which also covers 10x8 and doesn't look overly wide for only 40mm difference. I can't find any of my example shots from the Fuji online but below are a few examples from 210mm lenses. Discussing tech specs is all good and well but I prefer to look for example shots to see what a lens will produce. This is where I find Flickr invaluable especially when people tag their images with lens info. Cheers.
Nikon 210/5.6:
Docter Wetzlar 210/4.5:
A Cooke triplet is really a misnomer. A 3 element design by Dennis Taylor, who worked for T Cooke & Sons in York, he was chief engineer. Taylor & the company patented the design but never made them. Instead, Taylor. Taylor, & Hobson obtained the licence.
Essentially, the Taylor Cooke triplet was the first lens to correct almost all lens abberations. The Tessar was a derivative.
A triplet has quite soft focus edges and corners wide open, desirable in portrait lenses.
In real terms, think - a triplet is quite soft wide open except the centre, at a similar aperture a Tessar or type is better, a Plasmat tne sharpest.
Let's forget the faster dialytes, they are very sharp but low contrast;. The only one worth buying is the 203mm f7.7 Ektar.
I'd love to see some example pictures to illustrate all this discussion :)
Nikon 210/5.6:
Thanks for the input and pictures Nas, really nice work. I found your work Of BTS documenting shoots many moons ago around the time i got my RZ67. great work!!
I looked on flickr for examples. The search engine gave me mostly landscape pictures sadly. Seems like not many posted the Rodenstock 240mm f9. I found more examples of 210mm portraits.
B.S Kumar has already found me a Nikkor 210mm so I will stick with this and see how I get on. The Docter Wetzlar Character and tonality with the film looks beautiful. I love the 180mm Tessar lens on my rz67. The Nikkor Seems to have more contrast but you used strobes.
Very interesting. Thanks for sharing this.
I must admit i have a soft spot for Tessar lenses. My ocd is telling me to keep all my lenses the same brand or from the same country:rolleyes:. Sad I know loool
Yeah, no kidding. I've had the joy of trying to focus a 65mm f/8 Super Angulon on a 'Baby' Speed Graphic and it's not a lot of fun.
You may be right, it may have been marked as a Caltar-E, I've not actually looked at the badging in some time. It remains one of my favorite outdoor lenses, along with 203mm f/7.7 Ektar (which is a whole other level of stupidly sharp lens).
If I were to shoot portraits on larger format, I would more likely resort to the 8 1/2" Commercial Ekar in my stable. It has a "look" that I think favors human faces.
There are two issues here. First the Graflex focus screens are quite poor, a new screen can be more than two sops brighter. The second is at f8 the DOF of a 65mm lens makes it harder to focus. I have a 65mmf8 SA, which I have used on my Wista a few times over the past 35 years.
Interesting discussion.
I'm back in the studio on Monday and I'll be playing with a variety of lenses on 4x5" for now.
I too decided on the 200mm+/- focal lengths, at first, for all of the reasons mentioned.
I'll be using the Sinar with behind the lens shutter and flash sync. Wish me luck, I think I'm going to need it!
Lenses top left to bottom right;
Sinar to Linhof adapter lens board
Brass f8 (RR?)
8" Wray Lustrar ser.ii f8
F. Suter Aplanat no.4 f6
Brass Orthoscope f8
Computar f9
Projection/magic lantern (triplet)
Rodenstock Recti-Aplanat f8
Goerz Rectiplanat no.2 f6
P...&Rayment Rapid Euryscope Optimus f6
Heliar f4.5
Brass f8 (RR?)
Brass Orthoscope f8
Computar f9
Heliar f4.5
:oops::eek: so many!! It would be great to see comparisons. What film are you planning on using? I should have the 210mm by next week from Kumar.
If you ever need a foster carer for any of your lenses, Im here to give them a loving home looool.
I just received a mamiya x5 loupe. This loupe has eaten its weetabix! its not petite lol. It makes a big difference from my peak x5 plactic glass loupe. The adjustable focus is so so helpful.
Really pleased you're picking up a proper 210mm. You can't go wrong with a decent 210 and I don't believe you'll ever regret it. Likewise with good loupes.
All of these old lenses are fun but I wouldn't want to only rely on barrel lenses. The ones below 200mm just seemed a little too wide for now and similarly the 240mm+ asked for a lot more bellows extension, so the 200's are a nice compromise.
I forgot one that's on the F2, a Leitmeyr Sytar 21cm f4.5. I'll take 10 lenses and 10 dds and see how I get on!
A few 8" to 210m lenses.
L to R top: Dallmeyer 3B 8¼" f3 Portrait Petzval, Squire 8" f6 Pettzval, unknown 8" f6 swirly Petzval.
Kodak Lts 203mm (8") f7.7 Ektar, in Epsilon shutter,Wollensak 8¼" f4.5 Raptar, 3 8" RR lenses the front one is probably a Beck., CZJ 210mm f4.5 Tessar.
Eastman Kodak 203mm f7.7 Ektar in a Comur #1, Osaka Commercial (Ccongo) 210mm f6.3, Rodenstock 210mm f6.8 Geronar, Schneider 210mm f5.6 Symmar S
