Equipment ID
thronobulax
Not quite LF but at least good size MF.
I have the camera below. It accepts standard 9x6/3x2 sheet film holders. In fact, it came with some very nice thin metal sheet film holders that are quite slender by comparison to the usual wooden/plastic ones.
I believe this is a Zeiss Maxomar of some sort, model unknown to me. The back is removable indicating the ability to mount a rollfilm back in place of the sheet film/ground glass back it already has.
I should very much like to acquire the rollfilm back that mates with this, but have absolutely no idea what to look for, model or part number, name, etc.
Any help in this regard would be most appreciated ...
Not an expert but with a 105mm lens I suspect that it's a 6.5x9 camera, I have a similar and have a rollex back for it..
Yes 6.5x9 not to be confused with the 6x9 format.
Pre-WWII Rollex and Rada roll film backs were made to fit 6.5x9 cameras, you need to know the edge fit.
Note that this list pre-dates Zeiss Ikon, but shows the many edge fits of German metal bodied plate cameras.
I think your camera probably takes the O fit holders. Rollex roll film backs are more common than the Rada, the later have an accessory plate you insert to shoot 6x6.
Haha,
yes, I got caught out with this - before I found that very image!
Oh, I should mention also that the width plays a factor too, I have a Certo and a Vag and although both seem to fit the film holders nicely the Rollex is fractionally too small for the Certo and if not fitted carefully can easily slip off - small tolerances..
I have a couple of 6.5x9 Rada holders, I'm not sure where I have put them, they are not Zeiss Ikon fit. One is NIB with the 6x6 insert.
Haha,
I drew that image . . . . . . . .
It's a mine field trying to match a roll film holder to a camera especially when sellers rarely know exactly which camera the holder they're selling will fit.
I usually get the holders for around £5 - £10 at a Camera Fair. The Zeiss Ikon edge fit is quite common, also more distinct.
ah, the one I saw wasn't quite the same, it came from a Rada catalogue, yours is much more informative!
Have you got a roll holder that fits an Ensign Special Reflex?
If this is a Maximar A 207/3 that, as you say, these were normally a 6.5x9 cm format. However, not only does a 2 1/4" x 3 1/4" sheet film holder fit perfectly, both the ground glass and the opening of the back that faces the lens are of the same dimension.
Interestingly, the camera came with 3 metal sheet film holders. 2 of them are set up as above and the other for 6.5x9 cm film.
So perhaps the camera was made for the US market, or at least an aftermarket sheet film back was available for the 2x3 film size. There was a Maximar 207/5 allegedly built for the smaller format.
The sheet film back has a lip on each side that slides through a groove on each side of the back of the camera. Still trying to suss out which of the above that might be.
