Graflok back dimension
monopix
I was trying to find out if there is a defined dimension for a part of the Graflok back. It's the ridge down the left side (if you have it to load from the right). Picture attached from the back of my Toyo G. It's the depth dimension I'm interested in. On the Toyo it's 3mm but is that a standard or is that just Toyo?
It’s just over 4mm on both my early/late graflex graflock backs , I am reading the same on your ruler in the picture.
Additional notes - it does not touch the focus screen spring frame when it’s seated , it does provide a stop with clearance for a fidelity dds to prevent over insertion so let’s the dds ridge on right side nestle into its groove on the back .
I think it needs some height to help keep light away from the film , the felt seals are top/bottom in the back but not left side where that ridge is.
OK, thanks.
It's 3.5mm on the Toyo if I measure it accurately. The picture is at an angle so doesn't show the true dimension.
The reason for asking is I have a 6x12 back which has a recess that sits over this ridge. The recess on the back is the same dimension so it fits OK. But, I have another camera from a Kickstarter campaign where this ridge is about 6mm so my back definitely doesn't fit that. Trying to determine if the Kickstarter camera has been made wrong.
Makes sense , I think the T distance is likely key here , it’s about 5mm as far as I remember and any roll film back has to present the film at the same T as a dds so to have any chance of fitting with a side/side roll it needs less than 5mm , the one sided roll film backs at 12cm I think there is only calumet may fit .
Smaller sizes fit largely inside the rectangle of the grafloc .
Ok I think I got that wrong - looking at 6x12 backs it looks like some will fit inside the rectangle with side/side rolls
Yes, from what I've now looked at, I think most do fit within the space. Only this one, it's a Guohua, seems to extend out further. But if the depth of the ridge varies between cameras then this back will only fit some and not others.
