- Aug 29, 2020
This is a scan of a workbook print I just made a multi-year, and now almost complete project to revisit all my old negatives. I have gone through something between 8-10,000 monochrome negatives (50+ years worth) and selected which ones to print (or reprint) in 8x10 as workbook images. My printing experience and much better VC technology has made images I thought to be dreck, rather wonderful in this process.
This is a sort of first pass at a "Best Of" attempt which will be significantly whittled down further to determine which ones deserve larger printing and all hanging (the prints, not me!).
I keep favorites from the workbooks here (the first whittling):
Some beautiful photo's there, thanks for sharing. I enjoyed looking through those, some stunners with beautiful tonality.
I'm curious about the following;
Firstly, your motivation and criteria for image selection.
And secondly, how to make a coherent body (bodies) of work?
Thanks for the offer !Thanks for the kind words. Very much appreciated.
Every format from 35mm, 645, 6x6, 6x7, 6x9, and 4x5 is represented there. All are scans of 8x10 prints, not negatives and have been adjusted on a more-or-less calibrated monitor to try to represent the print faithfully on a computer screen.
I am happy to answer questions of materials, film, developer, location, camera, lens etc. should you (or anyone) want to know.
Could you talk me through the photo of the large white ice cream parlour at the side of the river, the metering and dynamic range on that scene is awesome, the shadows under the floor and the pilings there are great, as is the shadow under the roof and the roof next door, I don't think I have ever seen such brilliant white like with that detail yet maintaining superior shadows, I want to know everything, film camera lens, metering , developer and time, print paper and exposure. It's a wonderful shot. I can even see through the blinds and into the shop.
20260430
gitbucket.tundraware.com
All this must be subject to the usual provisos on monitor differences.
The white planking isn’t paper-based white, as you can see where it meets the “ICE” sign. I would tentatively suggest a different explanation.
The image very successfully recalls the experience of seeing things in brilliant sunlight and it’s an unconscious memory of this that influences what we believe we are seeing.
The brilliance of the white has nothing to do with the separation of the mid tones. It is because it is actually white and has maximum contrast with the abundant deep black of the shadows.
Indeed you're right, but on-screen it's rather hard to tell the brightness of the paper base. The small difference between the white paint and the Ice sign remains.
Nevertheless, this print seems to recall the sensation of looking at something in bright sunlight. One almost screws up one's eyes.
The same tone on a different subject - let's say a piece of paper on a desk - wouldn't arouse the same reaction even if the print's tonal range was similar.
"Ice cream parlour" threw me. But I think you mean this image:
(It is actually an ice house for fishing boats.)
This was shot earlier this year in Naples, Florida in the US in a docking area called "Tin City".
It was taken with a Leica M5 and 35mm f/2 ASPH Summicron, almost certainly with an orange filter.
The image was exposed on Lucky SHD 100 at full box speed but reduced 2 stops for the orange filter factor. So the actual EI used was 25.
The M5 has a spot-metering-ish system but I do not recall exactly how I metered. Either I metered for the shadows and decreased the exposure from the reading by 2 f/stops or I metered for the bright wall of the building and increased the exposure from indicated by 2 f/stops.
The real trick to holding this range came from the film development. The film was developed in Pyrocat-HDC 1.5:1:250 . After an initial 3 min of prewet in water, I used a semistand development scheme: 1 min continuous agitation, rest, 10sec agitation at 16 min, rest, remove from developer at 30 min.
The long development time gives the shadows time to fully develop and also expands mid-tone contrast. The high degree of dilution caused the bright highlights to exhaust quickly (because we are not agitating very much) and this holds the wall in bounds.
Note that the Pyrocat staining also serves to mask grain somewhat, which is rather helpful with 35mm especially.
The print was made on Fomabrom Variant 111 VCFB using split VC technique. First the paper was exposed for the highlights with the soft filtration on the enlarger, then exposed a second time with hard filtration for the shadows. (The VC head is a Heiland LED 4x5 model mounted on an ancient Omega DII.) After fixing and a short wash, the print was toned in Kodak Rapid Selenium Toner 1+40 for somewhere around 3-4 min, and then fully washed.
The dry, flattened print was than scanned with VueScan on an Epson V800. Post production was on a more-or-less calibrated monitor using GIMP to try to get a digital image that was a close to the print as possible.
If this isn't the image you had in mind, please identify it and I will respond accordingly.
